Help needed with lights
Old Jun 28, 2005 | 06:22 PM
richard_xr2i1800's Avatar
richard_xr2i1800
Default Help needed with lights
Hello my bro's erst is got an odd problem with the lights, side lights work fine but when you switch to main beam they dont work, changed the blues and the switch but still no joy.
Any ideas people
Rich
Old Jun 28, 2005 | 06:24 PM
Oranoco's Avatar
Oranoco
Investigate the relays in the fuse board. There are two small ones that control the headlights. Had this crop up on mine a few years ago. I used a small screwdriver to bend the tabs in the board to give a better contact and she's been good as gold ever since
Old Jun 28, 2005 | 07:42 PM
richard_xr2i1800
nice one will give that a go, anyone else know of any other things it could be
Rich
Old Jun 29, 2005 | 06:09 PM
mark@fordrs.org's Avatar
mark@fordrs.org
check the wiring near the battery, theirs a few smaller wires in some sleeving coming from the posotive terminal, this is fuse wiring look for burn marks or corrosion on the wires under the sleeving, this wiring gives the feeds for the dip and main beam.
Old Jun 29, 2005 | 06:13 PM
turbo.jon's Avatar
turbo.jon
this is what was wrong with mine relay ended up melting an catching fire
Old Jun 29, 2005 | 06:21 PM
mark@fordrs.org
my wires burnt out whilst i was on my way home' good job the brakes worked well!
Old Jun 29, 2005 | 06:25 PM
richard_xr2i1800
OH nasty better get it sorted asap, cheers for your help everyone
Rich
jessie_rs
11
Jun 3, 2019 04:57 PM
col93saphcos
Aug 7, 2015 03:21 PM
sridgett
15
Aug 3, 2015 07:26 PM
