Normal brake fluid container on RST master cylinder
Old Jun 28, 2005 | 08:22 AM
Rallyesport's Avatar
Rallyesport
Default Normal brake fluid container on RST master cylinder
Does the normal brake fluid container fit on the RST master cylinder? I'm considering removing the modulators when changing the clutch. I could plug the return hoses, but fitting a normal container would be better if it fits.
Old Jun 28, 2005 | 02:25 PM
John Laverick's Avatar
John Laverick
Yes it does fit....although it is quite difficult to push through the master cylinder seals.
Pick one up from your local scrappy for a fiver
Old Jun 28, 2005 | 05:08 PM
turbo.jon's Avatar
turbo.jon
yes will fit had no problems with mine when doing it
JK12
33
Apr 26, 2021 12:09 PM
massivewangers
30
Oct 1, 2015 07:40 PM
IainRS1700T
Sep 25, 2015 06:44 AM
focus2351
Sep 9, 2015 09:33 PM
cossirob
Sep 3, 2015 09:17 PM
