s2 wont run on standard dizzy marks?
Old Jun 23, 2005 | 09:59 PM
Mr.h.'s Avatar
Mr.h.
Default s2 wont run on standard dizzy marks?
The belt timing belt is spot on, but when the dizzy is set to the standard marks it wont run, but it will if you fully advance it but then the belt timing reads that it is retarded and needs to be more advanced but there is no more adjustment!!!
It has a Kent cvh34 cam,Superchip,-31,double valve springs,not an impressive spec but i just cant get it run right
Tried the knock sensor plus air leaks even a new dizzy and metering unit but still the same prob?
Im told that the kent cvh34 will and should run using standard marks?
Please help
Nick
Old Jun 23, 2005 | 11:04 PM
GrimmeRS2K's Avatar
GrimmeRS2K
my kent 34 is on the standard timing marks, runs fine, designed to, how do u mean not running right?
Old Jun 23, 2005 | 11:07 PM
Mr.h.'s Avatar
Mr.h.
It wont even run when using the standard timing marks on the dizzy and head???
Old Jun 23, 2005 | 11:14 PM
GrimmeRS2K's Avatar
GrimmeRS2K
u have changed the ecu then, the vacuum pipe to the ecu is ok, a small leak can cause problems, has it not run since installing the cam and springs?
Old Jun 23, 2005 | 11:19 PM
GrimmeRS2K's Avatar
GrimmeRS2K
also pull the air charge sensor off and try it
Old Jun 24, 2005 | 12:55 PM
IANS2RST's Avatar
IANS2RST
sounds like the leads are on wrong, move the leads on the cap along 1 pin clockwise
bigryrs
Mar 28, 2016 09:11 PM
bigryrs
Fiesta RS1800/RS Turbo
14
Jan 21, 2016 09:54 PM
Red_bull
Aug 25, 2015 06:27 PM
Roosie
Aug 15, 2015 08:09 PM
yawiejon
15
Aug 9, 2015 06:36 PM
