Actuator setup
Old Jun 23, 2005 | 09:58 PM
GraphiteGray's Avatar
GraphiteGray
Default Actuator setup
Following on from the other thread how do you set it up so its operating properly? ive set the rod on the new one slightly longer because with it set at the same length as the old actuator it was pulling tight on the wastegate lever and i was worried it might cause damage
Do you have to give it a run or something?
Cheers for your help, im new to this turbo lark
Old Jun 23, 2005 | 10:13 PM
S1MAN's Avatar
S1MAN
You need to set it at half a hole pre-load.
Colin.
Old Jun 23, 2005 | 10:15 PM
GrimmeRS2K's Avatar
GrimmeRS2K
it has to be tight over the wastegate,,u need a boost gauge really, the shorter the thread u can see, the more boost u will run, as always with increasing boost, make sure its checked by a tuner, ie fuel
Old Jun 23, 2005 | 10:30 PM
Mr.h.'s Avatar
Mr.h.
Colin.
What does that mean then?
Nick
Old Jun 23, 2005 | 10:35 PM
GrimmeRS2K's Avatar
GrimmeRS2K
when u can see only half a hole through the rod against the wastegate bit,
Old Jun 23, 2005 | 10:50 PM
Mr.h.'s Avatar
Mr.h.
Sorry mate still dont get it
Any chance you can shed some light on this for me?
https://passionford.com/forum/viewtopic.php?t=128879
Old Jun 23, 2005 | 10:59 PM
GrimmeRS2K's Avatar
GrimmeRS2K
the end of the rod, the part what screws in, has a hole in it what goes onto the wastegate bit then the circlip goes on to hold it there,
when installing the actuator, when looking from underneath, with the rod hardly screwed in, hold it up to the wastegae, and it should go straight over the wastegate,
but adjusted pre load (screwed in) if u hold the rod up to the wastegate it will be half the hole over it, then u have to pull the rod onto the wastegate
get it mate?
timsrs
Nov 13, 2018 11:48 AM
steve.rst
Mar 15, 2016 08:01 AM
Fezman1
Oct 2, 2015 01:22 PM
A.t.p
Sep 29, 2015 05:04 PM
SMILER258
Sep 28, 2015 09:04 AM
