Saff T34 boost hose help needed quick !!!
Old Jun 22, 2005 | 09:50 PM
david's Avatar
david
Default Saff T34 boost hose help needed quick !!!
Wouldnt normally post this up on main page but I desperatly need a boost hose for T34 turbo to filter (using K&N filter) right now or else were not gonna get the car set up in time for Croft next weekend
Any help would be great
Old Jun 22, 2005 | 10:05 PM
Alvyn's Avatar
Alvyn
if your using the standard Ford black pipe then it WILL go over the comp hsing fairly easily and if your using a Samco etc get a bucket of boiling water and soak it for a while and it will become plyable to also pull over the comp hsing/filter if your stuck
Old Jun 22, 2005 | 10:10 PM
david's Avatar
david
Think its a standard hose on the car, if not ive deffo got one off my saff somewhere.
Will give it a try tomorrow Alvyn
Old Jun 22, 2005 | 10:13 PM
Alvyn's Avatar
Alvyn
could also use a bit of washing up liquid around the edges
Old Jun 22, 2005 | 10:22 PM
david's Avatar
david
mmmm better get the lube out
Old Jun 23, 2005 | 06:19 PM
Ginge !'s Avatar
Ginge !
just finding my feet
i got a hose available if needed, its blue with a takeoff and not at all restrictive, i know as when i took it off and fitted my rouse one the car started to chatter higher pitch showing turbo stall
pm me if ya interested
Old Jun 24, 2005 | 10:47 AM
david's Avatar
david
you have PM Ginge
mk22door
49
Mar 26, 2022 07:15 AM
biggiejody
Insurance
Sep 2, 2015 12:04 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Gadget
Ford Escort RS Cosworth
Aug 13, 2015 06:43 AM
col93saphcos
Aug 7, 2015 03:21 PM
