Water temp gauge
Old Jun 16, 2005 | 08:42 PM
rs_daz's Avatar
rs_daz
Default Water temp gauge
Ive just brought a few gauges ...one is a water temp gauge just wondering how plp have wired theres in....I was just gonna wire it to the standard water temp sensor ...?
Old Jun 16, 2005 | 10:28 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
My Defi sender screwwed into the original sender hole, bloody handy
Old Jun 16, 2005 | 11:08 PM
rs_daz's Avatar
rs_daz
So have u done away with the normal gauge in the dash an just got the defi?
Old Jun 17, 2005 | 08:55 AM
Tony Turbo's Avatar
Tony Turbo
Yup
Old Jun 17, 2005 | 09:46 AM
swanny's Avatar
swanny
oooo very nice looking indeed
One question - where is ur petrol gauge ?!
Old Jun 17, 2005 | 11:27 AM
Tony Turbo's Avatar
Tony Turbo
Thank you Swanny.
The fuel level gauge is in a specially made panel under the radio
Old Jun 17, 2005 | 03:53 PM
rs_daz's Avatar
rs_daz
Looks smart tony ...
Do u think i could run 2 gauges off the normal temp sensor at the front of the block? ie in dash gauge and my new auto gauge one?
Old Jun 17, 2005 | 09:23 PM
Tony Turbo's Avatar
Tony Turbo
Errrrrm possibly.
My Defi has a different sender to the Ford one, and is faar better quality, I would guess that they vary alot and are matched. Why not dump the Ford Guessometer all together?
Old Jun 18, 2005 | 12:31 AM
rs_daz's Avatar
rs_daz
Well the sensor I got with my gauge is just the same as the ford item..
Il try a few things
Old Jun 22, 2005 | 03:54 PM
mark-rst's Avatar
mark-rst
Default Running temps
what sort of temps do you see on the gauge when norm running?
Old Jun 22, 2005 | 04:12 PM
Arjan's Avatar
Arjan
your autogauge should come with a separate sender, u could try to measure the resistance of both senders with a multimeter,when their about equal u could just split up the ford sender. otherwise, you might want to fit the sender into yr thermostat housing, theres a hole in it which u need to drill out,the sender fits in quite nicely,its just taps itself into the alloy.apply a small coat of glue around the top of the sender and the housing,job done.
Old Jun 22, 2005 | 05:42 PM
Arjan's Avatar
Arjan
niceeee looks so much better!
did u use the original ford sender unit?
Old Jun 22, 2005 | 05:55 PM
rs_daz's Avatar
rs_daz
Default Re: Running temps
Me???
Mine never goes over half way
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
DAZZER
Sep 30, 2015 08:43 PM
