please please please help me with rising revs
Old Jun 15, 2005 | 11:47 PM
Combi_Chris's Avatar
Combi_Chris
Default please please please help me with rising revs
hi guys, i have had a good look on this forum but cant seem to find what im looking for......
when i start my car from cold she ticks over fine , then as she gets warmer the revs seems to rise , after 5 miles of driving the revs are sitting at over 3000 . its annoying the whole street and me also. if i turn the car off at this piont it wont start again for at least an hour , sometimes it will start right away sometimes it wont .
it seems to get worse when the engines warmer . and sometimes the btrake pedal goes rock solid. always when the revs are high .
please help me people , i dont know what to do, i can only say that i ''think'' it might be a split pipe somewhere ???
mucho thanky in advance. PS . WOULD A DEAD BATTERY MAKE IT DO THIS ??
Old Jun 16, 2005 | 02:09 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
dude you need help. Let me have a look at your car for free and ill tell ya whats up with it.
Where is Essex r u?
Old Jun 16, 2005 | 02:20 AM
Combi_Chris
im based close to epping , m11 motorway and you ? ?
Old Jun 16, 2005 | 05:54 AM
tonyturbo's Avatar
tonyturbo
this is fook all to do with your problem mate but that is a stunning van.
Old Jun 16, 2005 | 07:55 AM
db's Avatar
db
Might be something wrong with your vacuum (brake master cilinder??), because you say the brake pedal is getting rock hard.
I would check all the vacuum lines first if 1 of them is torn or damaged in another way.
By the way that is a great van you own
Cheers.
Old Jun 16, 2005 | 11:56 AM
Combi_Chris
well the cars now off the road i will report what it was when its fixed , i cant drive it n`more
edit edit:: ive been messing about with all the plugs and so on, i got a new battery too, seems to be ''ok'' for the time being , i let her run until the fans came on , then she started ok and the revs are fine and tickovers back to normal, even when hot and after a blast
lets wait and see ..........
Old Jun 16, 2005 | 09:51 PM
AKRS1's Avatar
AKRS1
sounds like the vacumn pipe that goes from the brake servo to your inlet manifold. might be split or loose.
Old Jun 16, 2005 | 10:17 PM
Combi_Chris
its not that , i checked it , i think it could be servo master cylinder related , but then having said that when i started her up this morn as soon as i tiokk off the cold start plug it was fine, plug it back in and went loopy again, ill sort it eventually......
Old Jun 17, 2005 | 10:21 AM
Versus_Creations
Ask me a question!
just get it set up dude cos then you will find out what the score is. Im just off the M25 J28 A127 which is only two junctions away, i know you have taken it elsewhere now but if you get stuck let me know.
Regards
Jano
Old Jun 17, 2005 | 01:44 PM
Combi_Chris
no its still with me jano , the day i was fixing to come see you it played up big time then my battery died, it seems ok now, im getting a new servo/master cylinder at the weekend so should have that on mid week.........thanks for helping tho mate , i do appreciate it
TPM961
Jan 15, 2018 10:50 AM
Fil
Sep 30, 2015 12:08 PM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
