need advice on my turbo
can anyone help i have a s2 rs turbo and after a short journey the turbo is glowing red,also it wont boost till 5 thousand revs 1st and 2nd gear boosts at 11psi 3rd and 4th shoots up to 18psi plus the engine is standard patr from the dump valve
hi
it sounds like your timings out, to make the turbo glow
as far as the wierd boosting like that not sure mate but dont drive it
could be the amal valve but not should mate
If you want to keep your RS in 1 piece, I'd check timing and boost.
Std pressure is 8 PSI and fuelling will match that, the engine might survive 11 PSI, but 18 PSI is far too much for std fuelling.
My guess is you're on your way to a melted piston!!!
big_Rad
Sep 15, 2017 09:36 AM
Matt Baxter
Sep 16, 2015 08:30 PM
Ben26
Aug 27, 2015 08:56 PM
