Intermitent Temp gauge ?
Old Jun 14, 2005 | 01:59 PM
swanny's Avatar
swanny
Default Intermitent Temp gauge ?
Hi Guys,
I've been getting intermittent temp gauge readings for a while now. I've replaced the gauge but this hasnt really helped matters... I'm guessing that the sender unit or attached wiring is loose and is therefore only cutting in / out with the movement of the car.
Can anyone point me in the right direction for the sendor unit ? where is it located ? any tips on fixing this issue would be great,
Old Jun 14, 2005 | 03:12 PM
adamS2RST's Avatar
adamS2RST
Hi mate,
Likely your right it will be the temp sender. It is located near the thermostat housing it is a thin peice of wire with a rubber boot on the end that push's onto the head.
The rubber boot melts over time and causes a crappy connection. Had this with my old one, put another connector on and it was fine.
I'd check that first
Old Jun 14, 2005 | 05:52 PM
swanny's Avatar
swanny
Good lad... I'll go have a goosey now and see what I can sort out.
Cheers for the post mate
Old Jun 14, 2005 | 06:00 PM
swanny's Avatar
swanny
Just took a look now, Can see two electrical connectors going to the thermostat area - The larger of the two is a blue connector, the second is smaller and is a single wire.... guessing the later is the connection I am looking for ya ?
Old Jun 14, 2005 | 08:39 PM
B9DOV's Avatar
B9DOV
Yip m8 thats the wire you are looking for as adam s2rst described
Old Jun 14, 2005 | 10:49 PM
adamS2RST's Avatar
adamS2RST
That's it
How you get on?
Old Jun 15, 2005 | 01:23 PM
swanny's Avatar
swanny
I found it, might give it a clean up tonight when i get home from work.. when you say you put another connector on, did you just cut and re-join the wire ?
Old Jun 15, 2005 | 06:00 PM
adamS2RST's Avatar
adamS2RST
No mate, just vutthe end of the boot back as it was all manky and melted away, I didnt need to change the connector in th end.
Old Jun 15, 2005 | 06:04 PM
doggydowg's Avatar
doggydowg
bro i had this on my old white xrpoo and i changed the bit that goes into the block if cleaning it up dont work try buying the bit that goes into block there only a couple quid at partco
Old Jun 17, 2005 | 10:15 AM
swanny's Avatar
swanny
K nice one i'll give that a shot over the weekend.
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
