smooth running problem
Old Jun 9, 2005 | 04:26 PM
juss 1's Avatar
juss 1
Default smooth running problem
hi folks any one got an idea as to the solution to the following problem.96 N escort cosworth totally standard apart from induction kit and cat removed.on de-accelloration ie lifting foot of pedal the car judders and sometimes the revs drop right down and even stalls at times. on acceleration the boost comes in until roughly 3500 rpm then (although the gauge reads full boost) feels like it is just a 2.0 ltr car with no turbo. have changed plugs filter ect.the car runs perfect when on choke so im thinking it could be a fuelling problem.CHEERS in advance
Old Jun 9, 2005 | 04:32 PM
Dave Henshall's Avatar
Dave Henshall
dont nkow if the small turbo cars suffer from the dreaded corroded multiplugs behind the headlight under teh bonnet vent, thse when duff casue ALL sorts of gremlins
Old Jun 9, 2005 | 04:50 PM
juss 1's Avatar
juss 1
have checked them there in good condition.have been wrapped in polythene to stop the water getting in.but took it off to check anyway and all pins in clean good condition so sprayed some wd40 in and reconected and re covered.but thanks for advice.have noticed one of the pipes coming from amal valve that went to the old airbox is still in situ but obviously now just venting to air could that be anything to do with it as it would normally be recirculating back into air filtr box if fitted
Old Jun 10, 2005 | 07:47 AM
Dave Henshall
there should be a connection on the induction kit to plumb the pipe from the valve backinto it, but it shoudn't affect running just venting to atmosphere.
Old Jun 10, 2005 | 08:50 AM
bonmaklad's Avatar
bonmaklad
does it happen when u stop mostly cos i know so many cars that do that drops below 1k revs and then sometimes stalls someone told me it was an air flow problem garage fixes it for silly money
Old Jun 10, 2005 | 11:28 AM
sailorbob's Avatar
sailorbob
As Dave said the amal valve to airbox won't affect running as its such a tiny amount of air that gets vented. Have you still got the original reciculating dump valve and is it connected up as per norma?
Old Jun 11, 2005 | 02:50 PM
juss 1's Avatar
juss 1
sailor bob- its an 96 n small turbo model so there is no dump valve fitted
bonmaklad- does stall occasionally when i stop but the stuttering is mainly on lift off the pedal it feels as if for some reason there is a shortage of fuel for a split second.
THANKS to all for advice its appreciated cars is getting rolling roaded on monday so hopefully that will sort the problem out and ill inform you all if thats the case
Old Jun 15, 2005 | 11:24 AM
juss 1's Avatar
juss 1
well back now an appoligie to salior bob as ther is a dump valve but its fitted as part of the turbo and not on the throttle side where i was looking for it.SORRY mate.the diaphram was split in the dump valve so had that replaced and air flow meter was given a good glean cars runs a bit better but still not as it should be FORDS!!!!
Old Jun 15, 2005 | 11:51 AM
sailorbob's Avatar
sailorbob
Have you tried pulling any error codes from the ecu?
Old Jun 15, 2005 | 11:59 AM
juss 1's Avatar
juss 1
IM ASSUMING THEY HAVE DONE ALL THAT AS IT WAS IN GARAGE FOR A TWO HOUR DIAGNOSTIC CHECK.IM REALLY LOSING FAITH IN THIS CAR AS IVE ONLY HAD IT 8 WEEKS AND ITS BEEN NOTHING BOT PROBLEMS
Old Jun 15, 2005 | 12:05 PM
Combi_Chris's Avatar
Combi_Chris
stick with it , anythings fixable, it worked once it will work again.
Old Jun 15, 2005 | 12:06 PM
juss 1's Avatar
juss 1
JUST BEEN ON TO GARAGE AND THERE WAS NO FAULT CODES COME UP.HAS RECOMENDED REMOVING THE LITTLE CAT JUST BELOW THE TURBO AS IT COULD BE BLOCKING UP.LARGE CAT ALREADY BEEN REMOVED.
Old Jun 15, 2005 | 12:13 PM
juss 1's Avatar
juss 1
THANKS FOR THE SUPPORT COMBI CHRIS BUT EVER HEARD OF THE SAYING THAT YOU SHOULD NEVER MEET YOUR IDOLS AS THEY NEVER LIVE UP TO YOUR EXPECTATIONS THIS IS CERTAINLY TRUE OF MY ESCORT COSWORTH. WANTED ONE SINCE THEY CAME OUT FINALLY TAKE THE PLUNGE AND NOW THIS. BUT I SUPPOSE THE SWEET IS NOT AS GOOD WITHOUT THE SOUR
Old Jun 15, 2005 | 12:18 PM
sailorbob's Avatar
sailorbob
Looking at the small cat should be worth a try, a visual check will reveal if its clogged up.
Old Jun 15, 2005 | 12:22 PM
juss 1's Avatar
juss 1
IVE JUST ORDERED A FULL SYSTEM FROM THE TURBO BACK SO ATLEAST ILL SOUND NICE IF NOTHING ELSE.CHEERS FOR HELP LADS
Old Jun 15, 2005 | 03:32 PM
Dave Henshall
apparently, to reset the small turbo ecu, all you do is disconnect it from the loom for a few mins, then have to do its relearning asper in the workshop manual:
get it up to normal running temp, disconnect the ecu for a coulpe of mins, the reconnect and let it idle for 2 mins, increase the revs to about 1200, and hold there for a further 2 mins, the drive for about 5 miles varied driving to complete the learning sequence.
Old Jun 16, 2005 | 10:02 AM
juss 1's Avatar
juss 1
Cheers dave what will that do though?? i totally have no idea as to the workings on this car.so i have no idea where the ecu is i purchased a cd manual off the internet but it is like trying to find a needle in a haystack finding what you want as it is mixed in with large turbo and sierra models. i have the red key does that do anything with ecu as the previous owner said it resets every thing and only to use it in emergency
cheers for help mate
juss 1's Avatar
juss 1
Old Jun 16, 2005 | 10:10 AM
Dave Henshall
that will clear any fault from the ecu that its holding, and you need to relearn it otherwise it will drive and run like a bag-o-wank apparently
Old Jun 16, 2005 | 10:37 AM
juss 1's Avatar
juss 1
what will clear ant fault the key or the process you described. surely the garage that searched for the fault codes will have done all that resetting ect?? would nt you think.
Old Jun 16, 2005 | 10:51 AM
Dave Henshall
removing the ecu power will clear its fault codes adn it KAM (keep alaive memory) included in thsi are its idle and drive values, unless these have been re learnt properly it may still run crap even though there is nithing phisically wonrg or broken anymoe, ie, if the garage found a fault and fixed it, they may not have re learnt its idle and drive values....
Old Jun 16, 2005 | 10:55 AM
juss 1's Avatar
juss 1
Champion mate will try that then only one problem WHERE is the ecu is it behind that panel on the dash at the passenger side as per 3 door sierra.Hey dave just noticed your from macclesfield obviously youve heard of the macc ladds QUALITY
Old Jun 16, 2005 | 11:05 AM
sailorbob's Avatar
sailorbob
Just disconnecting the battery will do the trick, no need to hunt out the ecu. Leave disconnected for at least 10 minutes.
Old Jun 16, 2005 | 11:10 AM
juss 1's Avatar
juss 1
Cheers mate will give it ago if disconnecting the battery will wipe the memory that may be the problem as the car has stood with previous owner for 16 months with battery disonnected
Old Jun 16, 2005 | 02:11 PM
Dave Henshall
a haa!! the only problem with just the battery is u loose you rradio presets, the ecu is vaey easy to get to IMO, just at the side of the assenger footwell, the panel pull soff and the ecu is just slidup there, pull it out, and disconnect easy.
Old Jun 18, 2005 | 11:26 AM
juss 1's Avatar
juss 1
tryed all the above just now no change TYPICAL.
Old Jun 19, 2005 | 11:06 AM
sailorbob's Avatar
sailorbob
Have you fitted the new exhaust yet?
Old Jun 19, 2005 | 07:29 PM
juss 1's Avatar
juss 1
no not yet mate getting it done next monday
Old Jun 19, 2005 | 08:45 PM
davidreader5's Avatar
davidreader5
HI Juss,
Check all the hoses to and from the turbo to the inlet manifold including, the intercooler, for any loose hose's and also for vacuum air leaks, make sure your exhaust is free from any leaks before lambda sensor as will give problems to the lambda sensor to ecu, make sure your sensor's
connections are sound.im not sure with small turbo what fault codes it records weather throttle switch,? as large turbo covers 9 faults, doesent
cover tps.
DAVE R
Old Jun 19, 2005 | 08:53 PM
juss 1's Avatar
juss 1
cheers for advice mate will do them checks asap probs tomorrw as ive just got back from scotlands rsoc day.
paceo
Feb 3, 2016 10:31 AM
wheelwizardrefurbs
Sep 23, 2015 09:14 PM
kosienutter
31
Aug 22, 2015 09:55 AM
mattman1234
15
Aug 14, 2015 10:05 PM
Zoggon
Aug 10, 2015 10:39 AM
