coil pack ign HELP please, stu, simon sec's
just fitted my kit, all runnin.
but cant get either my std rev counter workin, or my auto meter rev.
tried into ecu pin 21,
std coil green,
with supressor bridged or connected.
any ideas.
runnin msd/sec's coil pack chip and loom.
on my p8 super 8.
std coil green,
any ideas.
on my p8 super 8.
got the auto meter workin, but only showin about 1/2 the right rpm.
on stu's instructions says pin 21 rev out put, 26 2nd amp output.
pin 21 does nothin for rev counter.
but pin 26 gets about 1/2.
any ideas?
any ideas?
just been out in it.
holdin 28 psi.
as before on group A coil etc etc, 0.5mm no miss.
opened it up to 0.8 mm missin so bad boost falls off, then trys to build up.
now at 0.65mm, but still a very slight miss top end.
so something needs sortin.
holdin 28 psi.
there was one of the other guys who had something similar, the board can only drive 1 tacho, if 2 are connected, neither work, SECS modded it , or sorted an extra driver specifically for that purpose i think.
Originally Posted by turboboss
with coil pack ign there is some sort of control box you have to buy
this is what the coilpack driver board does when fitted aswell as firing the other igniation amp,
Originally Posted by Ryan
nothing to do with the wiring, and you know it
ON either of our parts
and i can't comment on your wiring as i have never seen it you paranoid BUM...
hence the comment
I said its to do with YOUR (implying DAN's) Wiring.....
How is that something to do with me or you ? makes no sense - re the coment
Dan, i will give you a bell later to see if i can help mate
