Water Wetter etc
Jun 8, 2005 | 04:50 PM
Water Wetter etc
Has/does anyone use this, and would you recommend it?
Rick.
Jun 8, 2005 | 04:56 PM
I'll be keeping a watchful eye on this thread...
Jun 8, 2005 | 05:04 PM
we used it in the Superbikes to keep the temps down and also cos it is almost clear the scrutineers cant tell you are running coolant......
worked pretty good on the bikes brought the temps down a bit..
Jun 8, 2005 | 05:25 PM
got it in my saph and my dads series 2
Jun 8, 2005 | 05:31 PM
Got it in mine seems to help a bit
Jun 8, 2005 | 05:35 PM
Ive heard its good stuff
I dont use it tho yet
Jun 8, 2005 | 05:38 PM
rick you should of said you fancied some at tatton they had it for a tenner a bottle instead of burton's 20 quid
ebay sometimes has some for around a tenner tho anyways
matt
Jun 8, 2005 | 05:39 PM
Mixed with normal coolant fluid and water it does feck all on my car so dont bother unless you mix it with just water.
Jun 8, 2005 | 06:06 PM
If you wont look after your money, who will?
Jun 8, 2005 | 06:19 PM
what about radiator relief
Jun 8, 2005 | 06:39 PM
Rick, you could try, be an experience for it
Jun 9, 2005 | 07:07 AM
I used it on the escort!
knocked a few degrees off!
Jun 9, 2005 | 07:11 AM
I used it, worked well
Jun 9, 2005 | 09:05 AM
Quote:
Yep, the advantage isnt that its better than water, its that you dont need normal coolant any more.
Works a treat, minis use it due to their crappy side mounted radiator!
Jun 9, 2005 | 09:09 AM
Do u not use antifreee with it?
Jun 9, 2005 | 09:16 AM
is this the stuff
Red Line WATER WETTER Super Coolant
Helps Control Overheating
Doubles the wetting ability of water
Run up to 20 degrees cooler
Great for Cars, Trucks, Motorcycles, RVs, ATVs & Snowmobiles
Use with all Water-Cooled Engines
Also provides corrosion protection for modern cast iron, aluminium and brass systems
Cleans and lubricates water pump seals
Can be used with distilled or tap water
355ml - 12 Fluid Ounces
Price includes VAT
Jun 9, 2005 | 10:06 AM
You can only use it with just water on all aluminium engines.
Cast iron blocks still require you to use anti freeze to prevent corrosion.
Jun 9, 2005 | 12:41 PM
So basically, just chuck it in?
What about us that have alloy rads?
Jun 9, 2005 | 12:49 PM
Yeah just put it in with your normal 50/50 water anti freeze mix.
Its fine with Ally rads.
Jun 9, 2005 | 12:52 PM
i use it in mine, with antifreeze, does run a bit cooler, tends to cool down quicker when the fans kick in
put then mine never goes above half on the gauge
Jun 10, 2005 | 08:48 AM
Didnt really notice much diff on my car as she runs very cool any way with big ally Rad! But did notice that once it gets warm it cools down a lot quicker once moving agian!
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
DAZZER
Sep 30, 2015 08:43 PM
