Seam Welding
Ive got another fiesta Si (mk3) that im making in to na 2.0 track car. Ive heard about seam welding to strengthen the chassis. Sounds like a good idea but i dont know where to start. What exactly would i be welding???
cheers
cheers
Strip off all the soundsproof/sealant....front front to back identify all the points where the chassis fixes to the body (usually a 'U' section chassis spot welded to the body) and work down each (seam) stiching (welding)the lip of the chassis to the body...differing opinions onthe next part...weld the two together leave a gap then weld again down each seam....we usually weld approx 25mm leave approx 50mm....mark it up before you start to make it uniform...
HTH
Regards
Ian
HTH
Regards
Ian
HTH
Regards
Ian
HTH
Regards
Ian
Thanks
Take it to Dave Colledge at Retro Ford (www.retro-ford.co.uk), get him to sort your cage too.....
It might cost a bit..... but grown men will either cum or cry when they see the cage etc.....
SMILER258
Sep 28, 2015 09:04 AM
