help ,i need to do a rebuild on the rs turbo
Old Jun 6, 2005 | 07:53 PM
iggy gt4's Avatar
iggy gt4
Default help ,i need to do a rebuild on the rs turbo
i need to do the bottom end,i am gonna take the engine and box out and strip it on sat, so how much work is it to put a 2l bottom end on it?????????
i was told it's easy but u need to mess about with the water pump,is this right????
also whats the best to go for is it the mondy or a saff bottomend??????
and when i get the bottom end will i have to change the pistons and stuff inside so it lowers the compression or not??????????
also will the engine mounts be the same,mind thats not too bad i can get them made up,
if there is any who has done it can u pm me what i will need, cheers,
Old Jun 6, 2005 | 09:53 PM
iggy gt4's Avatar
iggy gt4
Old Jun 7, 2005 | 07:14 AM
iggy gt4's Avatar
iggy gt4
no one have done it,
where's alex when u need him
Old Jun 7, 2005 | 07:18 AM
Cowboi's Avatar
Cowboi
its the zetec bottom end u use. thats why its called a zvh after the conversion.
other than that i aint to sure what u need. its a shame the search thing aint working as im sure this has been spoke about a few times before
Old Jun 7, 2005 | 07:21 AM
swanny's Avatar
swanny
Try doing a google search for ZVH mate, i'm sure there are a couple of pretty good web sites out there that go through the ZVH conversion step-by-step
Old Jun 7, 2005 | 07:24 AM
swanny's Avatar
swanny
This one seems pretty good
http://www.quantums.info/zvh.htm
Old Jun 7, 2005 | 07:26 AM
Cowboi's Avatar
Cowboi
have a look at that
Cowboi's Avatar
Cowboi
what can i say, great minds......
Old Jun 7, 2005 | 07:40 AM
iggy gt4's Avatar
iggy gt4
wooooooooooo hooooooooooooo cheers
Old Jun 7, 2005 | 08:22 AM
Cowboi's Avatar
Cowboi
Old Jun 7, 2005 | 09:59 AM
Ginge !'s Avatar
Ginge !
just finding my feet
the quantums one is fior a 1.8, theres a tiny bit more ya gotta do for 2.0, you cant machine 2.0 pistons but the 1.8 ones ya can,, also need to ally weld the head a tiny bit too, the breather as to be blocked, the water pump changed as it runs the wrong way, the block needs tapping for the oil return and i think thats it
Old Jun 7, 2005 | 10:46 AM
Cowboi's Avatar
Cowboi
welld one ginge, ur the man
Old Jun 7, 2005 | 10:51 AM
iggy gt4's Avatar
iggy gt4
oooooo now it's getting too compilcated,so if i use a 1.8 it is a straight swop??
but a 2l is loads of work by the sounds of it..........why is nothing easy....
Old Jun 7, 2005 | 11:00 AM
Ginge !'s Avatar
Ginge !
either way ya gotta rip ut the pistons unless ya use a decomp plate
its not that much work and can be done quite easy
also on a 2.0 ya need the 1.8 escort sump and oil pickup pipe aswell
JK12
33
Apr 26, 2021 12:09 PM
slammedorion
15
Nov 1, 2015 07:17 PM
Matt Baxter
Sep 16, 2015 08:30 PM
kevin36
Sep 2, 2015 06:24 PM
