Help 1.9l with OFAB efi
Old May 12, 2005 | 04:41 PM
1.9s1's Avatar
1.9s1
Default Help 1.9l with OFAB efi
Has anybody on here put a 1.9l engine in a fiesta turbo with ofab management? i need to know if it will run without mapping the ecu, i know for optimum power it will require mapping but for now should it be driveable without it
Cheers, mark
Old May 12, 2005 | 05:33 PM
sailorbob's Avatar
sailorbob
EEC-iv management knows the engine displacement and it uses this to calculate the injector duration, if you change the displacement but not the calibration it'll not get the AF ratios right. The OFAB ecu doesn't have a HEGO sensor and you won't get any adaptive learning to help compensate.
Old May 13, 2005 | 05:45 PM
1.9s1's Avatar
1.9s1
Thanks for that mate so the only way to get this running properly is to have it mapped? where is the best place to get this done?
Cheers, Mark
Old May 14, 2005 | 06:10 AM
Badman38's Avatar
Badman38
you can run it in without mapping i ran my 1.9cvh on obfac for 2000 miles before setting it up stuart of motorsport developments can map it for u
Old May 16, 2005 | 08:32 AM
sailorbob's Avatar
sailorbob
Just because an engine runs doesn't mean you aren't harming it. If you can find a tuner who has mapped the same spec engine as yours they should be able to do a 'safe' running in map without seeing the car. You might even find a tuner who would give a partial refund on the cost of the running in chip if you then went to them for a proper mapping after running in.
Old May 16, 2005 | 03:53 PM
1.9s1's Avatar
1.9s1
Thanks for the advice guys. Just booked it in at msd for mapping 9th july
mk1turboestate
Dec 2, 2015 08:31 PM
liamT74
Sep 23, 2015 10:24 PM
davidfordrs
Sep 21, 2015 04:23 AM
RSmark84
Sep 13, 2015 01:29 PM
dms04
Sep 11, 2015 01:57 PM
