Help Bias box and hydro clutch issues.
Old Apr 7, 2019 | 09:58 AM
3drRich's Avatar
3drRich
Default Help Bias box and hydro clutch issues.
Morning all. I’m in the final stages of putting my track car together and have a couple of questions I need help with.
The first is I’ve put fluid in the hydraulic clutch and bleed it through and it seem to have a pedal although seemed quite stiff but now I seem to have a small amount of fluid coming out between the gearbox and engine so can only assume it’s leaking from one of the hoses on the centre bearing, was I supposed to put ptfe on the threads maybe? Also the burton quick shift I have installed seems very stiff but maybe this is because I haven’t had the engine running for long yet?
2nd issue is I’ve fitted a comp brake bias box with hydro clutch conversion, straight swap my arse, and none of the pedals seem to line up properly, is there a way of adjusting these?
These are are the final bits for my car to be finished so any help would be most appreciated.
Old Apr 7, 2019 | 05:00 PM
Caddyshack's Avatar
Caddyshack
Comp brake stuff is very much not a straight fit in my limited experience. Their 205 on needed huge mods.
there is a fluid you can add to brake and clutch joints like a liquid ptfe.
are you sure the slave is not leaking? Can you get a camera in there?
Old Apr 7, 2019 | 05:31 PM
3drRich's Avatar
3drRich
Hi Toby. I’m just in the process of splitting the engine and gearbox to have a look, can’t see in there with it in place. I bought a brand new hydraulic clutch for it as I didn’t want to take a risk with the old one that was already fitted so can only assume it’s one of the pipes.
Old Apr 8, 2019 | 01:15 PM
Caddyshack's Avatar
Caddyshack
Hopefully it is just something simple. Just a pain having to do it.
-beefy-
17
Apr 13, 2012 09:25 PM
Jim Galbally
50
Oct 6, 2008 07:22 AM
Deleted by Request
11
Feb 15, 2008 10:22 AM
Ginge !
15
Nov 17, 2005 11:33 AM
