fiesta zetec s idle adjustment
Rs500 DataBase Editor
From: In the Karate Dojo , or updating the rs500 database
my friend's car is idleing at 1100 rpm then drop's to 1000 rpm he want's to know if it can be adjusted cheers
nope, unless he has a 5 sided allen key
its a sign of his idle control valve on its way out... the zetec will alway idle a little high and then drop, try taking the ICV off and give it a blast with carb cleaner
for more advice on this, go to: http://www.ukfiestanetwork.com
