cossie yb engine stood for 4 years will it need bearings etc before restart
stripped my cossie 4 years ago for a rebuild and soon ish the engine will be going back in a few people have mentioned about putting shells in it as its been sat and not turned over , any input would be great
I would firstly replace the cambelt, once done I would take the plugs out, turn it over by hand on the crank for several revalutions, then disconnect injectors and coil, put some fresh fuel in and allow to circulate (switching on and off a few times shiould help) then turn it over until the oil pressure light goes out.
replace plugs and reconnect injectors then start
you may want to change the oil and filter before aswell, also check oil level before you turn it over
Steve
Steve
From: it's not where you are, it's where you've been and where you hope to be
replace the belt, pull the dizzy out and drive the hex shaped dizzy/oil pump shaft with a drill till the oil pressure comes up then pull the plugs and spin it on the starter with the injectors disconnected to get oil circulated. then start it
If the engine hasn't been stripped just removed whole it will be fine, I'm baffled by some of the answers here
lol
Nothing is going to hurt the bearings unless it's been left outside and full of water, I would just service it and start it, I've used engines that have been stood over 10 years, the only issues I've seen are seals get hard with age and can leak
I can never see any sense in fixing things that aren't broken it's just work creation imo
lol Nothing is going to hurt the bearings unless it's been left outside and full of water, I would just service it and start it, I've used engines that have been stood over 10 years, the only issues I've seen are seals get hard with age and can leak
lol
lolNothing is going to hurt the bearings unless it's been left outside and full of water, I would just service it and start it, I've used engines that have been stood over 10 years, the only issues I've seen are seals get hard with age and can leak
Steve
peanut_coz
Aug 3, 2010 08:42 PM
Roosie
78
Mar 1, 2009 12:55 AM
LHD220Turbo
84
Jun 14, 2008 10:25 PM
filthyrichie
16
May 6, 2006 11:57 PM
