Short bodied master cylinders .
As above , I'm after some cheap short bodied master cylinders in 0.600 or 0.625 and 0.700 or 0.750 ..I've looked at the 76 series Tiltons which are perfect at 2cm smaller then the normal wilwoods.. only problem is thier £174 each ..so I'm just wondering if there is other makes with the same sizing i could use that are cheaper. ?
Thanks Mat.
Thanks Mat.
Thanks Mat.
Thanks Mat.
stu21t
May 16, 2006 08:26 PM
L33 BYT
Feb 14, 2005 08:33 PM
