YB standard internals power limit ?
Old Jan 26, 2019 | 12:09 PM
cossie51's Avatar
cossie51
Default YB standard internals power limit ?
Trying to work out if I can safely push more power out of my engine as it's still running a standard bottom end with valve pockets in the pistons.
Currently maxed my T34/63 at 426bhp holding 21psi boost so looking in to a turbo change but not sure what to go for and how far I can push it and keep some sort of reliability as I'm not looking to do a full rebuild and spec change just yet.
car is on New Link G4+ management with all safety strategies enabled.
Told by my mapper it's good but so restricted by the turbo and something newer and larger would transform the car even more.
Old Jan 26, 2019 | 12:40 PM
5hane's Avatar
5hane
Which block do you have?
If 200, is it long studded? - I would imagine keeping the head bolted down would be your limiting factor
426 is a lot of power for a 34/63, has it been modified? (billet wheel/ cutback blades etc)
Old Jan 26, 2019 | 12:42 PM
dan le moignan's Avatar
dan le moignan
Surprised by the power thought about 27psi held was around 380?
iam in the same boat holding 27 psi but want abit more about 450hp, standard low mileage engine, had new grp N head gasket about 10k ago.
Old Jan 26, 2019 | 12:56 PM
scoooby slayer's Avatar
scoooby slayer
426 hp at 21 psi on a t34 a physics defying turbo then lmfao
Old Jan 26, 2019 | 12:59 PM
cossie51's Avatar
cossie51
It's a 200 block but has ARP Stud & Nut kit fitted which was done correctly to the ARP specs. Head is mildly ported and polished with bd16 inlet cam and AS Plenum and 65mm id electronic Throttle body so free flowing hence the low boost pressure. When on the standard inlet set up it was holding 30 psi on the same turbo.
Old Jan 26, 2019 | 01:06 PM
cossie51's Avatar
cossie51
Dyno graph shows the figures
Old Jan 26, 2019 | 01:07 PM
Adam-M's Avatar
Adam-M
If longstudded a standard 4x4 engine should do over 500 don’t know how good the arp boot setup is
Old Jan 26, 2019 | 01:18 PM
scoooby slayer
The turbo must be flat out on a well specced motor on an engine Dyno to do that power imo
cossie51's Avatar
cossie51
lots of people say they crack blocks but read in to it and it seems it's luck of the draw ! When reading up on it they said loads were install incorrectly hence cracking orthers said they had been at 500bhp with no problems and a few said they were installed correctly and still caused cracking in the deck face.
Dont really want to pull engine apart to long stud at the moment as when I do take it apart I want to build a bulletproof engine but not really got the funds to go that far at the moment.
Old Jan 26, 2019 | 01:21 PM
cossie51's Avatar
cossie51
the turbo is flat out hence wanting to know what to use turbo wise and how far I can push it and keep reliably till funds allow for a big spec bulletproof engine build.
Old Jan 26, 2019 | 01:33 PM
scoooby slayer
Are you looking for a direct fitment turbo ? A t38 or a T4 should be a bolt in replacement, old hat but will get the job done. I'm not sure what needs changeing to fit an efr or similar modern turbo
Old Jan 26, 2019 | 01:39 PM
Adam-M's Avatar
Adam-M
I don’t think cosworth would of redesigned the block to suite longer studs if they could of got away with standard length studs that don’t stretch like standard studs
Old Jan 26, 2019 | 01:52 PM
cossie51's Avatar
cossie51
Don't see the point in paying out for an old technology turbo as don't want to he car to be laggy with all the power up top.
An EFR would require a twin scroll manifold and a down pipe mod which is no problem. My mapper suggested the new Garret G25 series turbo which would require modding my manifold or a replacement but I don't know anyone that has fitted one to know if they work with a YB. There may be other modern turbos that I could use ?
the questions are what turbo, what size, internal or external wastegate, and how far I can push the engine but keep it reliable.
Im looking to try and find a happy medium where I can run more power by changing turbos but keep it reliable and safe at the same time. I would rather get a smaller power gain but be safe than a big gain with the fear it's going to go bang at any point. If that makes sense.
Old Jan 26, 2019 | 02:01 PM
cossie51's Avatar
cossie51
The ideal step forward would be long studs but mine has the ARP kit fitted on a running engine so not looking to take it apart to long stud it yet. That will come when it comes out for a big power spec rebuild.
i wasn't trying to imply ARP Stud kit was a fit and forget, just currently working with what it's got.
Old Jan 26, 2019 | 02:22 PM
Caddyshack's Avatar
Caddyshack
Mine did 469bhp on 7064 efr, standard engine and would have done more but high intake temps
Old Jan 26, 2019 | 02:46 PM
dan le moignan
Toby were you on standard 4x4 inlet?
Old Jan 26, 2019 | 02:49 PM
scoooby slayer
On a 200 block motor I ran 472 hp with standard head bolts without issues, some of these modern turbos might fit internal gate with just a mod to downpipe needed
Mark Shead will know what will fit, or a gt30 maybe
Old Jan 26, 2019 | 03:07 PM
turbotrev's Avatar
turbotrev
Has the engine had a rebuild?
You say it's got pocketed pistons and an arp bolt kit which all ain’t standard so it’s not really a standard bottom end...
What head gasket you on?
if it’s all in good nick and has a decent head gasket I’d say between 450-500 and you should be ok.
Especially if not running crazy boost levels
Cheers Paul
Old Jan 26, 2019 | 03:49 PM
Caddyshack's Avatar
Caddyshack
at the time yes. And a not very good rs500 style cooler. I swapped to a Hart later and will probably go individual bodies next.
Old Jan 26, 2019 | 04:44 PM
cossie51's Avatar
cossie51
Cheers Paul
Paul, it's on standard crank, rods, and pistons but valve cut outs were machined in so I could run bigger cams. Engine has done about 4K miles since it was built 5 years ago including 1500 miles on a running in map. It's got a multi layer steel WRC head gasket fitted,
turbo has only been pushed to its limit since it had the Link management fitted and mapped in Nov 18.
Its the black saph you posted pics of last Sunday in cobham services !
Old Jan 26, 2019 | 08:11 PM
dan le moignan
Cool didn’t know if a small turbo plenuim would be needed around those figures
Old Jan 26, 2019 | 08:15 PM
Caddyshack's Avatar
Caddyshack
some people fit a spacer but finding a 2nd hand hart or the copy is worth having....I believe. A good intercooler is an important part, worth having a chat with Mark Shead on a few options.
Old Jan 26, 2019 | 08:18 PM
dan le moignan
Did read about the spacer but most say it’s the elbow that’s the real restriction it seems.
Guess smaller the inlet the less lag?
Old Jan 26, 2019 | 08:59 PM
Caddyshack's Avatar
Caddyshack
‘Not sure the inlet size will affect lag unless we are talking really big volumes to fill...I could be wrong though? I guess it’s about speed of airflow and less restrictions means less heat. I know the Hart flows better and with a nice top feed spec r, alternative or even airtec top feed you get a better cooling and a bit more power if mapped to suit. (Or can run more boost)
Old Jan 26, 2019 | 09:17 PM
dan le moignan
Guess very minimal,
I have an airtec RS500 cooler at the moment and never really goes over 28 degrees once moving in the summer, not sure how good the flow is though
Old Jan 26, 2019 | 09:32 PM
charlie luciano's Avatar
charlie luciano
I ran a gt30/71 on my Sapphire on a standard engine that had been rebuilt a few thousand miles previously, have to say it didn’t last very long, the engine let go during a live road map and upon strip down there was milk at the back of the engine where the head bolts to the block.
Prior to the live map when I had fitted a few more spangly bits chasing more horse power the car ran 420 bhp with 400 ft/lbs torque. It had switchable maps low boost 15 psi high 30 psi.
if you are chasing big horse power 400+ you’ll definitely need a decent rebuild with long studs imo
Old Jan 26, 2019 | 09:40 PM
scoooby slayer
My last saph was built by an ex nms employee, 200 Turkish block, 7.2 c/r, wrc gasket and standard head bolts, ran a T4 msd live mapped to 2.2 bar above 5300 rpm, 472 hp and never gave any problems, it can be done and be reliable
30-130 mph was 12-13 seconds iirc
Old Jan 26, 2019 | 10:20 PM
cossie51's Avatar
cossie51
After lots of reading it looks like a internal gated EFR 7064 would give me what I am looking for power wise without to much stress on the engine.
Anyone tried the new G25 series turbo yet or know if they are as good as the EFR turbos seem to be ?
Old Jan 26, 2019 | 11:11 PM
turnover's Avatar
turnover
If your engine is running fine at the boost and revs your running just put a gt30 with a 63 or 82 housing at the same boost you will make more power,as long as it’s re tuned and injectors and fuel system is adequate you’ll be fine
Old Jan 26, 2019 | 11:34 PM
cossie51's Avatar
cossie51
Gt30 or Gtx30 gen 2 ?
O44 pump and ID1050x injectors so fuel supply shouldn't be an issue!
Old Jan 26, 2019 | 11:35 PM
turbotrev's Avatar
turbotrev
Mate I didn’t even notice sorry, car looked sweet last week btw.
It sounds like it’s in decent nick then and 4k miles ain’t a lot, and a proper headgasket fitted too.
So I’d say easy 450-500hp.
Like many have said choose a decent turbo for another 50-80hp and you’ll be good.
Lots of turbo choices out there, new Garrett, Owens GTB, efr’s, small gt30, etc
Cheers Paul
Old Jan 26, 2019 | 11:39 PM
turbotrev's Avatar
turbotrev
Good advice this
Cheers Paul
turbotrev's Avatar
turbotrev
GT30 not GTX
Cheers Paul
Old Jan 27, 2019 | 11:58 AM
dan le moignan
GT3071R seems an easy option with the Cosworth housing so it can go straight on a standard manifold?
same lag as T34 from what the majority say.
i quite like the way the power comes in on the T34 As love that turbo surge of power.
Lazy part of me says throw a GT30 on but guess the efr makes sense for the cost of a manifold?
Old Jan 27, 2019 | 12:11 PM
cossie51's Avatar
cossie51
I'm tempted to try the new Garret G25 series but as they are still quit new theirs not a lot of info as to if they are as good or better than the likes of the EFR plus their is no twin scroll option available at the moment but it's meant to coming soon.
Old Jan 29, 2019 | 09:13 AM
R4N SS's Avatar
R4N SS
It is the elbow that is the restriction - on my old engine on the 2wd inlet i had the elbow modified so it wasnt as restrictive and also had a 14mm spacer added.
New engine has a hart inlet on it which im sure will be much better
Old Jan 29, 2019 | 09:38 AM
timsrs's Avatar
timsrs
4x4 inlet has much less restrictions
and a lot less to buy.
Old Jan 29, 2019 | 11:03 AM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
I had a small turbo escort inlet and throttle body on my 500bhp engine. That was the best option of the 3 standard ones
Old Jan 29, 2019 | 11:26 AM
scoooby slayer
My old one had a 4x4 inlet with spacer iirc, bd14 cams and a T4 at 2.2 bar, but it maxed out at 472 hp I'm not sure what stopped it achieving 500 hp though
Old Jan 29, 2019 | 01:35 PM
Caddyshack's Avatar
Caddyshack
Mine was 469bhp at 2.2 bar and held back by intercooler temps...pretty close boost and power to yours
