Shock absorbers for lowering...
Old Jan 21, 2019 | 12:03 PM
LukeLJB's Avatar
LukeLJB
Default Shock absorbers for lowering...
Hello all.
I have a mk4 escort estate and I’m looking for a 40mm drop. I have found a nice set of lowering springs but I’m unsure of the shocks? Can I use the standard ones or do I need aftermarket ones with 40mm less travel. Or, can the original ones be modified?
Also is there anything else to replace when lowering. The car is sitting on 14 inch alloys.
Thanks
Old Jan 21, 2019 | 12:27 PM
djmca's Avatar
djmca
Bring back old skool Ford
Originally Posted by LukeLJB
Hello all.
Thanks
You should be fine with the standard shocks, anymore than 40mm and the spring may be too short and thats an MOT fail so you would need shortened shocks. As long as your shocks, bushes etc are in decent condition you are good to go
back2black
Fiesta's Other !
Jan 28, 2012 06:59 PM
pumacar
Mar 2, 2005 04:48 PM
Adder
Mar 2, 2005 01:48 PM
kevsrs
Oct 31, 2004 09:11 AM
James Raby
Jul 23, 2004 08:25 PM
