Pf01 vs Pf09
Old Dec 6, 2018 | 08:54 PM
Rsmat's Avatar
Rsmat
Default Pf01 vs Pf09
Any differences to each other ? Only my mapper has told me to get a PF09 as my PF01 doesn't show closed throttle ?
this was the message i got ...
The pf01 has a switch which shows open circuit with closed throttle so that's not going to work unfortunately. The pf09 is the one we need. Ie any other 0 to 5v sensor.
I'm sending him a PF09 so he can carry on ..on Saturday when he's back from Scotland.
Old Dec 6, 2018 | 09:41 PM
Adam-M's Avatar
Adam-M
Yeah mate they are 0-5v but they work opposite to each other, one will be 5v at idle going down to 0v the other starts at zero.
i take it the simtek can’t work with a pf01?
Old Dec 6, 2018 | 09:45 PM
Rsmat's Avatar
Rsmat
ah got ya mate that's why then ..and yea it's the simtek I've had fitted ..won't work with the PF01 then
Old Dec 6, 2018 | 09:47 PM
Rsmat's Avatar
Rsmat
So swapping the outer wires round like when you got L8 on a l6 loom not work mate ?
Old Dec 6, 2018 | 10:01 PM
Adam-M's Avatar
Adam-M
I’m pretty sure spwapping the wires only enables you to run a pf09 on a 2wd loom and vise versa. If your stuck I could dig out my pf09 and meet your mapper up here so he’s got it.
Old Dec 6, 2018 | 10:08 PM
Rsmat's Avatar
Rsmat
Ah got ya ..so it's deffo the pf09 I need then ..I'm pretty sure he's mapping a car at Andy Gallaghers mate ..mega thanks for the offer but I've just posted one out for him to area 52 ..top man Adam really appreciate it mate
Old Dec 6, 2018 | 10:13 PM
Adam-M's Avatar
Adam-M
I can imagine it being frustrating being held back by something like that, yeah I know he does Andrews mapping and he more that likely passes through my town on the way to AG.
Hope you get get it sorted bud
markk's Avatar
markk
Its because the PF01 goes open circuit at idle. Useless to any ecu other than Weber setup.
Old Dec 6, 2018 | 10:55 PM
Rsmat's Avatar
Rsmat
cheers Mark that makes sense mate
Old Dec 6, 2018 | 10:57 PM
Rsmat's Avatar
Rsmat
Yea it's cool mate ..Steve let me know and I'm in no rush for car as I'm flat out at work so works in my favour tbh ..I'm going DWB after Xmas etc so it will be redundant then the TPS
Old Dec 7, 2018 | 06:19 AM
Caddyshack's Avatar
Caddyshack
I think I have one you can borrow
Just seen above that you have one and an offer but mine is here if you need them
Old Dec 7, 2018 | 08:16 AM
Rsmat's Avatar
Rsmat
thanks Toby mate ..top offer .hopefully the one I have sent works ..I'm.sticking the DBW TB on after Xmas ..I think the old cosworth stuff is a pain now a days
Old Dec 7, 2018 | 02:05 PM
Adam-M's Avatar
Adam-M
DBW does seem the way forward that’s what I’m going mate
Old Dec 7, 2018 | 02:09 PM
Rsmat's Avatar
Rsmat
yea I've got all the bits .. would have fitted before mapping but I didn't want to take the inlet off to have altered to fit DBW this side of Xmas .
Old Dec 7, 2018 | 03:02 PM
Caddyshack's Avatar
Caddyshack
I want individual throttles on mine but to go dbw I either need to find that driver for my vipec or swap to emtron and I don’t fancy another about turn and buy again.
Old Dec 7, 2018 | 03:23 PM
Adam-M's Avatar
Adam-M
what thorttle body and pedal did you go for?
Old Dec 7, 2018 | 05:17 PM
Rsmat's Avatar
Rsmat
Mk7 fiesta pedal and Audi A4 TB mate
Old Dec 7, 2018 | 05:21 PM
Adam-M's Avatar
Adam-M
Is that throttle body the same bolt pattern as a cossie one?
Old Dec 7, 2018 | 09:03 PM
Rsmat's Avatar
Rsmat
Yea according to Andy it is mate ..have you seen the vid he's put on FB today with the simtek set up on a board working the TB and everything ?
Old Dec 7, 2018 | 09:14 PM
Adam-M's Avatar
Adam-M
Good stuff mate I’ve got the one off a 1.8 20vt which is a direct fit (MarkK’s recommendation) I’m assuming yours will be the same part
Did see the video it’s an impressive package especially for the money
Old Dec 7, 2018 | 09:59 PM
Rsmat's Avatar
Rsmat
yea that's the one mate bolts straight up same as A4 TB then ..Yea lot of spec for the money the simtek is.
Old Dec 15, 2018 | 01:01 PM
Rick's Avatar
Rick
Don't use either, the are both ancient, The advantage of standalone is you can use modern cheap sensors.
Old Dec 23, 2018 | 02:08 PM
Rsmat's Avatar
Rsmat
used a PF09 for now ..working perfect ..switching to DBW in 2019
timsrs
May 8, 2016 06:43 PM
boXXer
Apr 16, 2011 03:13 PM
JokerDisco
Aug 18, 2009 10:30 AM
Ryan
Dec 30, 2006 12:18 PM
Disabled Account
Jan 24, 2005 06:08 PM
