focus mk2.5 vibration when driving at speed problem
Car drives smooth around town but once up to about 70mph get a constant vibration which can be felt though steering wheel and accelerator pedal, even passenger in front can feel it. Any ideas of places to start looking? Im thinking tyres/ wheels
car is a 09 focus 1.6 petrol
Thanks for all replies chaps,
tbh its been like this for a good few months, but as i rarely use it Ive forgot about the issue, My wife however uses it everyday, not at motorway speeds admittedly. but she doesnt seem to ever notice anything.
Still haven't got round to looking at it yet due to weather,
tyres are fairly obvious what to look for but what would i expect to see on a drive shaft thats causing a vibration?
Make sure the outer drive shaft spider joint that goes into the inner shaft is ok. The inner shaft also has a bearing which sits in a bearing carrier which is bolted to the engine. Make sure the bearing is ok.
Have you had the wheels balanced?? This might be the cheaper option too.
Well had a proper look yesterday, front drivers side was slightly more worn on the inside but the drivers rear is totally fucked, the inside edge is like a 50p coin! have to wait till the weekend again now to vet them changed.
how does this happen? most fords i have had seem to destroy tyres before they actually wear out. My old mk2 Mondeo did it, my fiesta mk5 and old sportka have both made the rear tyres '50p'
Thats the thing, i would like a PROPER wheel alignment done, but i think most of the places around my way don't know what there doing. You end up with a steering wheel pointing off centre when the car is driving in a straight line and things like that.
If you want to come to Southampton I can give you his details.
There is also a place near to me in melksham that isn't too far from you. I've never used then but they are supposed be very good at alignment and have all the latest gear. I can get their details if you like.
Off the subject for a minute, Melksham is where Spec-R used to have their factory, not sure if they are still there. Years ago when I bought my group A air box off them for my Saff I took it there as I had a problem fitting it and they sorted it out.
So I went to the tyre fitters today.......
they said the wheel / tyre which is worn unevenly is slightly buckled. So not worth replacing tyre on a buckled wheel until I've got it repaired or replace the wheel.
I'm assuming the buckled wheel has cause the tyre to wear this way.
this sound right to you ?
The rear suspension also has a camber adjustment on it. I’ve not long had a mk2 focus and just got a full polly bush kit for it. But I’ve had to order a rear bolt kit as there meant to be a c@@t to change and you normally end up cutting the bolts off. I’ll get mine fully tracked up when there all changed
It's Czech Mate
Jul 21, 2004 01:44 PM
