18inch wheels on Escort Cosworth
Old Nov 6, 2018 | 08:30 PM
oibren85's Avatar
oibren85
If in Doubt Flat Out...
Default 18inch wheels on Escort Cosworth
Evening all,
Looking at 18's for the Escort but was wondering what is required to get 18's on. Car has standard suspension. Hear most like an ET of 15 so guessing that brings the wheels out a little. Would it rub on standard suspension or just sit too high and worth getting a lowing kit and dampers?
Thanks in advanced.
Old Nov 6, 2018 | 09:28 PM
turnover's Avatar
turnover
You can put them straight on but depends on width and et ,but you could always run a spacer if tyres too wide etc
Old Nov 6, 2018 | 09:55 PM
oibren85's Avatar
oibren85
Cool so theres space in the arch for the size. Do we know what the best size is? Will it look high with standard suspension.?
Old Nov 7, 2018 | 05:27 AM
grcossie's Avatar
grcossie
I got 8x18 et 15 Mo6 With 235/40x18 on standar suspension, no problem at all
Old Nov 7, 2018 | 02:35 PM
TrevCos's Avatar
TrevCos
People do put them on with standard suspension, but it will look too high.
Old Nov 7, 2018 | 05:39 PM
grcossie's Avatar
grcossie
Mine on oe suspension
Old Nov 7, 2018 | 06:06 PM
TrevCos's Avatar
TrevCos
Are you sure?
Old Nov 7, 2018 | 08:24 PM
turnover's Avatar
turnover
Probably on lowering springs
Old Nov 7, 2018 | 09:34 PM
grcossie's Avatar
grcossie
It`s old used oe springs and avo dampers on that picture. I have Ahmed springs and bilstein b6 on the shelf for here. I use 234/40 a bit higher then 225/40 or 235/35 as i`v seen on some other escos
Old Nov 8, 2018 | 03:35 AM
stevenebm's Avatar
stevenebm
post whore
you will be fine with et15.mines are coming in at et5 and they look perfect.fill the arches nicely.
Cosworthfreak
Jan 26, 2011 10:07 PM
24vcossiemat
Aug 14, 2010 12:15 PM
leo_cos
Aug 12, 2010 07:37 AM
PDH11R
Mar 13, 2007 07:43 PM
Alloy wheels and ICE for sale
Dec 26, 2005 08:25 PM
