Mk4 mondy trailing arm bushes
I need to replace the trailing arm bushes on our Mondeo, there is a special tool to change these without removing the arm from the car which I don't really want to buy to use once.
Does anybody know of somewhere in the Hertfordshire/Bedfordshire area that has the tool?
I'm not taking it to a ford dealer just in case anyone thinks of suggesting that!
Yeh the tool is about 150 quid. I've noticed my mk4 mondeo rear bushes are starting to split.
we have done a few at work and we borrow the tool off a garage from around the corner.
I did some and found them ok, but a bit of a struggle as the tool that I used (Sealey) weighed a ton, so was easier with 2 people doing it.
Once you get all the tool with all it's plates and collars lined up level etc it pushes out the old bushes ok.
https://www.ebay.co.uk/itm/232179836406
Lambchop
27
Mar 19, 2008 12:48 PM
cossiecrew
16
Mar 8, 2005 06:50 PM
