is it likely to get through another MOT?
Old Aug 28, 2018 | 11:08 AM
Robsters's Avatar
Robsters
Default is it likely to get through another MOT?
So I have aging old 17yr old 2001 fiesta with 1.3 Endura E Engine on 116k almost, its MOT is due in 2 months and my mechanic warned me for the past yr that they are condemning a lot of the old mk4/5 fiestas now at the MOT and mine does sadly have rot on rear arches as well as sills been welded once in 1 area at last MOT, should i be prepared for this to be condemn at the next MOT this year ?
Old Aug 28, 2018 | 11:27 AM
haz87's Avatar
haz87
Its the same as any car (not even going to say old car as plenty of new ones rot). So sort the rot or expect it to fail. Don't really know what answer you expected as the make/model is irrelvant - the same MOT applies to all
Old Aug 28, 2018 | 06:52 PM
If your arches are rusty just put some duct tape over them. As long as there isn't any sharp edges they should be ok.
Old Aug 30, 2018 | 07:06 PM
TrevCos's Avatar
TrevCos
Yep, arches will be ok as long as there's no sharp edges, and if the sills/chassis rails are solid even if they've been welded they should be okay. I was talking to an mot tester not long ago and he said the amount of tranny vans they had in with rotten arches was unreal, but they can't fail them on that.
rog
May 11, 2012 04:09 PM
bstuff
Aug 10, 2009 12:27 PM
ford_courier
Jun 27, 2006 11:37 PM
Steve F
Apr 11, 2006 11:17 PM
XRTypeRS
Jun 27, 2004 08:22 PM
