oil change...
14000+ post superhero
diesel turbo car specs synthetic 5-40 but has 140000 miles on it. would you stick with 5-40 or go for a thicker grade 10-40 or 15-40 because of the high mileage?
5w-40 will only be thinner at cold engine temps, so wouldn't affect operating temps; So really a 15w40 will only be thicker in cold temps on startup - which isn't really ideal or going to help you.
It's only the "warm" temp (the 40) thickness which will be thicker at operating temp; so the only place to go would be 5w-50/60, which is a bit pricey as you will never get any benefit from running that high of a grade oil.
I would say stick too what the manufacturer specs.
bought it today. went for the manufacturers recommended grade. 8 and a half litres required was a bit of a kick in the balls but ECP has a 35% off week on just now so that took a bit of the sting out of it
Ł83 for the mobil1 oil after the Ł44 discount. my previous cars have only ever needed a single 5 litre bottle.
changed both the air filters yesterday, they looked like they had a wasps nest in them, must have been about 50% blocked so the car feels that little bit sharper now ! maybe gain another tenth of a second on the 1/4 mile
spadey
May 5, 2006 11:00 AM
Taz
May 27, 2005 01:42 PM
