Sierra LSD
Old Jun 13, 2015 | 02:38 PM
paulmex's Avatar
paulmex
Default Sierra LSD
Sorry if this is a daft question but I'm a old school mk2 guy not Sierra based at all
About 10 years ago I broke a 2.0 4x4 Sierra 1991 100k on a j reg ( I bought it as it had a YB fitted )
I kept the axle as it seemed to have a LSD fitted showing all the signs like my old escort ones ,
So present day I'm have a sort out and dig the diff out and wip the cover off to find this ?
I'm used to old escort ones where the plant /sun gears are hidden , but this is exposed ? It's thicker on the Crown wheel side which I'm guessing is where the plates are ? So what diff have I got ?
Cheers paul
Old Jun 13, 2015 | 03:22 PM
james kiely's Avatar
james kiely
paul you have the standard diff that came in the xr4x4 which has a 3.9 ratio .
the diff is the same lsd as the 4x4 cosworth but that has the 3.64 gearing.
Old Jun 13, 2015 | 04:20 PM
paulmex's Avatar
paulmex
Thanks James, it was the physical difference to LSD,s I'm used to that threw me
Old Jun 13, 2015 | 05:14 PM
markk's Avatar
markk
You are used to plated, this is viscous.
Old Jun 13, 2015 | 06:43 PM
paulmex's Avatar
paulmex
Yep usually quaife ones with the ramps crack and bang style !
chowfornow
14
Jan 5, 2019 09:01 PM
Nov 1, 2015 06:53 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
dalmarshall
Oct 1, 2015 06:46 PM
Fil
Sep 30, 2015 12:08 PM
