Cosworth gearbox tunnel
Old Mar 27, 2015 | 11:09 AM
Weepeeps's Avatar
Weepeeps
Default Cosworth gearbox tunnel
Guys does anyone know if a cosworth tunnel is different to a bog standard saphire tunnel. I need one for my mk1 cortina cosworth project but can't find a cossie shell that someone's cutting up cheers in advance. Stew
Old Mar 27, 2015 | 12:33 PM
Guinnless's Avatar
Guinnless
It's the same.
Old Mar 27, 2015 | 12:54 PM
Caddyshack's Avatar
Caddyshack
Originally Posted by Guinnless
It's the same.
+1....the same
I know Burtons do a lot of pre-fab stuff.....do they not have something off the shelf you could use...even if you need to add some sheet to it?
If you are going 4wd I would also pre-cut and weld the hump for the chain (transfer case) to accept the Skyline box too as you may want to go big power and this would be a much cheaper route.
Old Mar 27, 2015 | 03:44 PM
Weepeeps's Avatar
Weepeeps
Cheers guys that's a big help just staying 2wd. I think that's enough for my skill level! I'll get a build thread posted up over the weekend stew
Old Mar 27, 2015 | 10:05 PM
mk22door's Avatar
mk22door
Fart of the Purniture
No, they are not all the same!
Early Sierra's have a smaller tunnel.
Some Sierra's don't have the 'bulge' area.
Later Sierra's you should be okay with.
Try and go for late model fitted with a 2wd MT75.
Old Mar 28, 2015 | 07:29 PM
mk1turboestate's Avatar
mk1turboestate
Will the gearbox not fit in the car as it is? I have a t5 fitted in my mk2 escort with a standard auto tunnel
Old Mar 28, 2015 | 07:40 PM
Weepeeps's Avatar
Weepeeps
Nah came with a type 9 in it which was a tight enough fit. T5 is hoooge compared to that! I think auto shells have a bigger tunnel
SmudgerByName
52
Jul 28, 2016 06:14 PM
CLIVE
Oct 2, 2015 12:58 PM
wheelwizardrefurbs
Aug 15, 2015 05:54 PM
Aug 14, 2015 07:29 AM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
