Zetec engine weight
Old Mar 26, 2015 | 12:30 AM
westfieldturbo's Avatar
westfieldturbo
Default Zetec engine weight
Just incase anybody want to know the weight of there engine as I have ! I have just weighed my 2.0 SILVERTOP turbo only thing of the engine is the oil filter as it doesent come past my steering rack but engine still has oil in the sump external wastgate turbo intake manifold injection engine mounts fuel reg and still a few pipes attached and comes in at 144kg
Old Mar 26, 2015 | 07:42 PM
studabear's Avatar
studabear
Why are you doing this, have you broken it?
Old Mar 26, 2015 | 08:15 PM
westfieldturbo
Neh the clutch release bearing started makeing a right screeching so thouht Id better get it done now that everything's running right . keeping in mind it takes the same time to get the engine out the westie as it dose to do the front wheel bearings or my landcruiser so no big deal just over an hour to whip it out . Was also considering a lightened flywheel while it's off
JoeyBoyden
Jan 4, 2024 02:36 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
track.focus'd
Aug 12, 2015 05:53 PM
