Transit 2.4tdci warm starting problem
Old Feb 25, 2015 | 06:10 PM
B man's Avatar
B man
Default Transit 2.4tdci warm starting problem
Hi folks,
I'm a newbie with an extremely frustrating warm starting problem with my transit 2.4tdci rwd.
The van starts from cold first time and runs smooth. Once the engine reaches running temperature, the bugger won't start when you turn it off.
Once it cools down, boom it starts again. It will start instantly with a bump start when it's warm but just turns over with the key and won't ignite.
So far I've,
Checked the fault codes with a reader, none
Changed the fuel filter
Checked the injectors and fuel returns for leaks
Checked all the fuel lines and filter housing.
It did have a stored fault code saying the egr valve was jammed open but when I wiped it it stayed away and there's no management light on. So I assume it's an old code.
It's an ex rac van with a cracking history etc and it's been fantastic up until last week after being stood for 3 weeks while I was on holiday and then it started playing up.
Any help would be much appreciated as I'm ready to take the 22ton excavator to it!
Thanks.
Old Mar 3, 2015 | 12:17 PM
roger69's Avatar
roger69
Did you get your van sorted. If not I would try a slave wire direct to the started solinoid from the battery in case the ignition switch is playing up on start position(make sure its out of gear with ing on when doing this)
Old Mar 3, 2015 | 05:27 PM
B man's Avatar
B man
Hi, yes I've tried that mate. When I'm turning the van over some times it's slow and sometimes it's very fast, I'm wondering if the starters drawing too much current and the ecu isn't getting enough juice therfor no start. The ignition is worn and if you wiggle the key it cuts in and out sometimes, so I stuck a new one in and still no start off the key. Tow the bugger 6 feet and it will start and run all day! This is whats leading me to the starter motor because with a tow we are by passing it and she starts.
What do you think? Thanks for replaying.
Old Jan 16, 2020 | 08:25 AM
Will Snailum's Avatar
Will Snailum
Hi mate. Did you ever find out what the problem was? My mates van is doing the exact same thing
Old Nov 30, 2020 | 04:32 PM
Betty transit's Avatar
Betty transit
Default Hi did you find out why your transit was acting as it was
Hi did you find out what was causing your transit it act like it was i know it was a while ago but mine is acting exactly the same.
Thanks
Old Dec 1, 2020 | 11:25 AM
TristanH's Avatar
TristanH
Sounds like an electrical issue, like a dodgy key switch or solenoid.
FOR FORDS SAKE!
Dec 12, 2017 07:16 PM
Dannybrady40
11
Dec 12, 2013 11:53 PM
Dannybrady40
Dec 12, 2013 09:36 PM
dmosey
Jan 30, 2013 01:40 PM
