Skyline cossie clutch release
Old Feb 10, 2015 | 06:26 PM
Caddyshack's Avatar
Caddyshack
Default Skyline cossie clutch release
I was wondering what people have used for the centre push clutch release.
The box I bought has the cossie bell housing welded on (by MK for previous owner) there is a centre push in the bundle but it seems the main shaft in to the gearbox needs machining down to allow the smaller bearing and before I remove any metal I would prefer to use a bigger diameter centre push but not sure if that would work with the cossie clutch cover plate?
What have others used? Thanks in advance.
Old Feb 11, 2015 | 04:37 PM
Caddyshack's Avatar
Caddyshack
Lots of views but unfortuantely no answers yet.
I can see that AP do a big range of diameters for the slave cylinders but I still need to find out how critical the diameter is for the cossie clutch cover and what throw it needs as they seem to vary 12 mm to 18mm, I guess the longer the better and just adjust the pedal stop in the car?
Old Feb 14, 2015 | 04:35 PM
Caddyshack's Avatar
Caddyshack
I think I am going to need to put the boxin and take it out quite a fe time s to get it right so I have made a cradle up with built in axle stands and trolley jacking points, still some work to do but t seems to work.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
