2001 ford fiesta rear light wont work
Old Feb 3, 2015 | 10:33 AM
alber1956's Avatar
alber1956
Default 2001 ford fiesta rear light wont work
drivers side rear light wont work,,,,, brake light works as does all lights inc drivers front sidelight all fuses ok changed bulb cluster panel earth wire ok just cant get the rear light to work was working before ,,
Old Feb 3, 2015 | 11:58 AM
studabear's Avatar
studabear
Have you tried a new bulb?
Old Feb 3, 2015 | 05:52 PM
alber1956's Avatar
alber1956
its had new bulb
Old Feb 4, 2015 | 02:16 PM
roger69's Avatar
roger69
Have you checked your getting a live to the sidelight use a 12v probe if no power it could
Be in the wiring.I had a sidelight go in my xr2 the bulb had blown changed the bulb still no light so checked the fuse it was OK so had to use a jumper wire from nearside light to get it working.Same happened with a sierra I had Hope you sort it out
CrOwSoN15
Aug 14, 2015 06:52 PM
RsS2daz
Aug 14, 2015 05:26 AM
sridgett
15
Aug 3, 2015 07:26 PM
