L8 loom connectors
Old Jan 4, 2015 | 02:25 PM
InFlammen's Avatar
InFlammen
Default L8 loom connectors
Hello
Just fitting a L8 ECU and proper loom to my 3dr Cosworth.
Need a bit of help, as I don't know the function for these two connectors.
Many thanks!
Old Jan 4, 2015 | 05:30 PM
Colly473's Avatar
Colly473
Originally Posted by InFlammen
Hello
Many thanks!
3 wire is lambda I think,2 wire could be a/c.is it a green label l8??
Old Jan 4, 2015 | 06:04 PM
InFlammen's Avatar
InFlammen
The loom is from a breaking car, and I have not seen the ECU, but the rocker cover was a red one. Perhaps it was not the original one.
Thanks a lot.
Old Jan 4, 2015 | 06:51 PM
Cossy Mike's Avatar
Cossy Mike
Thanks a lot.
Mines a saff red top 4x4 with L8 and has these 2 connectors.
If its the ecu loom, the 3 pin is for lambda sensor (was later used in the green tops) and the 2 pin was for a cannister purge (not used), air con as above
Old Jan 4, 2015 | 08:11 PM
InFlammen's Avatar
InFlammen
So it could be the original loom, but in red top the 3 pin connector was present but not used?
And... I don't understand what you say about the aircon (sorry for my bad English).
155lee
Oct 24, 2015 11:11 AM
muz
Sep 30, 2015 08:29 AM
Fudgey
Sep 17, 2015 01:06 PM
