Radiator flush
Old Jan 1, 2015 | 10:09 AM
Fordmad!'s Avatar
Fordmad!
Default Radiator flush
Ive got some rad flush in an attempt to clean the heater matrix up so I can have warm air
Is it just a case of putting it in the header tank then running the car for a bit?
Old Jan 1, 2015 | 09:26 PM
Colly473's Avatar
Colly473
Yeah throw it in as give it a good drive up to temp with the heater on.dont hold out too much hope,the super fine cores in most of the heater matrices can't be flushed easily
Old Jan 2, 2015 | 06:17 AM
Fordmad!'s Avatar
Fordmad!
No I don't hold much hope but for a fiver it cant hurt.
Even If I get a trickle of warm air id be happy for now until the summer when I can get the dash out!
Old Jan 3, 2015 | 03:33 PM
Toe Knee's Avatar
Toe Knee
I did manage to flush one out a bit many years ago with a jetwash!!
Disconnected the pipes at the bulkhead and from memory it worked pretty good!
Old Jan 3, 2015 | 03:52 PM
Fordmad!'s Avatar
Fordmad!
Yes this is the next move before changing the matrix. Its just tricky to get too
Old Jan 3, 2015 | 04:11 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Get down your local Daf trucks place and get some of are trp coolant flush! Really good strong stuff used for flushing cooling systems when the oil cooler go's. You put it in mixed with the right amount of water and run it for a few days
Old Jan 3, 2015 | 08:08 PM
tony66's Avatar
tony66
Default matrix
i have had decent results before flushing out both ways[flow and reverse]...usually with a mains hose decent pressure,had a steam cleaner hose on too before-cause if matrix is choked it can be a case of fook it or fix it...
Old Jan 9, 2015 | 09:26 AM
Toe Knee's Avatar
Toe Knee
Yea I did mine both ways, from memory actually left the hoses on at the bulkhead and stuck the lance in the ends as they were hard to get too!!
Old Jan 9, 2015 | 09:28 AM
Fordmad!'s Avatar
Fordmad!
Yes I may do it this way ^^^ as it looks very tight at the back there
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Chas
Oct 5, 2015 07:13 PM
