S1 will only start if bumped
Old Sep 27, 2014 | 08:14 PM
RetroTed's Avatar
RetroTed
Default S1 will only start if bumped
My S1 will only start if I bump it when cold, once its started it starts fine afterwards
Can anyone shed any ideas, the fuels there its got a spark so i'm boll**** if I know whats up
Does the oil make any difference as i'ts on running in oil at the moment
Thanks
Old Sep 28, 2014 | 10:28 AM
S2 Cabby's Avatar
S2 Cabby
Does it try and start or not turn over?
Old Sep 28, 2014 | 11:28 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
weak battery? engine will crank slightly slower with cold thick oil... try it with a jump pack or another car and jump leads
Old Sep 28, 2014 | 01:27 PM
RichieST's Avatar
RichieST
Don't also discount worn starter motor or high resistance through cabling. As said, try a jump start with jump cables connected direct to starter motor (carefully) and a solid part of the block.
Old Sep 29, 2014 | 10:40 AM
RetroTed's Avatar
RetroTed
It cranks over fine and the battery is new, however we have added jump leads too but this makes no difference
Old Sep 29, 2014 | 05:20 PM
scoooby slayer's Avatar
scoooby slayer
Does it fire at all when cranking cold? I have had this before and it was a bad earth cable but although the motor cranked it was slow and not quick enough to start
Old Sep 29, 2014 | 06:16 PM
mk2grp1's Avatar
mk2grp1
going sideways in a fwd
remove air filter , push the air flap down with ignition on, less than half a second
now try start it
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
rex647
Mar 6, 2022 06:20 AM
TPM961
Jan 15, 2018 10:50 AM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
