1.8td endero de plz halp
Hi all iv just fitted à td endero de in m'y mk3 fiesta it now wont start iv been told its run by à ecu m'y fiesta has never had à ecu iv been told i can bypass thé pump can Any tell me how to do this thanks alot paul
Is that thé one with a wire on top if so I put a 12v wire to it i can here it click when I take wire on an off it can i not just bypass it as it been hard finding parts for it lol thanks for all the halp
this is from memory so might not be 100% , last time i played with it was years ago !
if the engine was from a PATS immobilizer car :
To get to the shut off solenoid you will need to remove the pump , cut away a brass shroud on the back of the pump which covers the solenoid and there will be 3 black wire 2 need an ignition live the other needs earth , try different combo's until it starts easily (it may be possible with the pump in situ but i found it easier with it removed so i could see what was what)
non PATS immobilizer :
as above but the solenoid isn't covered with a shroud
28
Dec 10, 2003 07:46 PM
