General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Got a little spot on my rear arch just starting, its only got to the stage where the paint surface has started to turn brown, so hopefully this stuff will keep it at bay. Has anyone else used it? what were the results?
have had mixed results with this tbh couple of spots on my last car were sorted and did not come back but on the car before that it was back in weeks, guess its all in the prep
Have a look at this link and I would recommend the Deox Gel, it is really good and used properly works very well. It dissolves the rust without harming the surrounding paint or metal, when removed you'll be left with shiny metal that can be touched up !
yeah when i did a google search someone said Bilthamber was better, but i already bought the Hammerite stuff so ill give that a go first.
Cheers mate
It has been around for a while and I recently used it on a badly rusted motorbike petrol tank with good results, but it is not a miracle cure . The preparation is important making sure you get rid of all the surface rust and leaving it to dry properly after putting it on.
Cheers Richard.
