mk3 mondeo duel mass or solid flywheel now it needs replacement
Old Jul 9, 2014 | 09:00 PM
M K's Avatar
M K
Default mk3 mondeo duel mass or solid flywheel now it needs replacement
Id say within the next few months my mk3 mondeo 2.0 130 tdci 6 speed is going to need a new duel mass flywheel set up as its knocking and banging loudly when downshifting etc,
I may tackle the job at home as I can do it over a few days or however long I want to really as I don't use the car for work or anything. But I am in 2 minds whether to go solid flywheel set up or replace with another duel mass flywheel???
Any opinions or helpful hints to do the job or special tools needed please,
Thanks
Marc
Old Jul 9, 2014 | 09:43 PM
dojj's Avatar
dojj
Resident Wrestling Legend
Dmf replacement unless you are a mini cab driver
Old Jul 12, 2014 | 03:31 PM
M K's Avatar
M K
Anyone else got experience of these or fitting them?
Marc
Old Jul 12, 2014 | 04:01 PM
Fullflush's Avatar
Fullflush
Don't go solid, more vibrations and a potential to reduce box life
Old Jul 12, 2014 | 06:12 PM
I have done a clutch on a mk3 mondy years ago.I dropped the ns of the sub frame down and just slid the box onto the sub frame then got my hands in the gap to replace the clutch.It be a bit harder trying to get the fly wheel out though?
Old Jul 13, 2014 | 03:39 PM
silver's Avatar
silver
I had mine done last year and I put a solid flywheel kit on it.
About a month later I put a new dual mass in. The solid one is too harsh and
the gearbox input shaft would rattle at tickover.
Old Jul 13, 2014 | 04:22 PM
Harryh24's Avatar
Harryh24
I've changed a few to smf not at my recommendations. as they never feel right or change right and boxes usually don't last as long.
Old Jul 13, 2014 | 04:28 PM
philsford's Avatar
philsford
I have a 2.0 TDCI 6 speed with a solid Valeo conversion. It was quite harsh at first under 2000rpm but seems to have bedded in a bit now (I have done 20k since fitting).
When I priced the kits up there was very little diffrence in the solid or DMF so unless you will keep the car long enough to be replacing the next clutch you might aswell stick with a DMF. Mine is a mini cab and I think the car is good for 300k so I will need 1 more clutch to get to that milage. I have previously run a TDDI to 280k with just 1 genuine ford clutch and flywheel kit and there was nothing wrong with that clutch at 280k and it was fitted at 140k but it all depends how you drive.
Old Jul 14, 2014 | 05:38 AM
M K's Avatar
M K
Cheers guys
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
yatta
May 21, 2016 10:31 PM
Dr. Ickxs
Sep 15, 2015 10:15 PM
gcfcos
88
Sep 15, 2015 03:48 PM
Bighandsuk
Sep 2, 2015 05:23 PM
