Hyd clutch conversion T5
Old Jun 8, 2014 | 03:50 PM
jamie956's Avatar
jamie956
Default Hyd clutch conversion T5
Any advice welcome what's best centre push or slave and where to buy from.
Its in a Cortina and I have a pedal box which will take a master cylinder and I have approx. 50mm clearance between bell housing and tunnel.
Old Jun 8, 2014 | 04:16 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Sounds like you have enough space for an external cylinder but your clutch type could dictate which option you go for..
Old Jun 8, 2014 | 07:47 PM
jamie956's Avatar
jamie956
Heilx paddle and cover,
Currently struggling to get it to work on a cable I have a shitty OBP pedal box had to lengthen the pull arm to get more throw but now the extra leverage is just twisting the hole box, hoping a hydraulic system will be a bit lighter on it,
Old Jun 8, 2014 | 07:50 PM
Martin-Hadland
A hyd conversion using an external cylinder will fix the issue and have a much lighter / nicer pedal feel.
Old Jun 8, 2014 | 08:20 PM
jamie956's Avatar
jamie956
Will be giving you a call in the morning, I have a spare .625 m/cyl will this be ok for the pedal end.
What modifications are needed on the bellhousing.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
SMILER258
Sep 28, 2015 09:04 AM
