ignition problem urgent help/advice please
My sierra sapphire rs cosworth 4x4 on a K plate has a problem the car turns on fine but when you go to turn it off the car stays on with the key in your hand it won't turn of unless you stall it and also all the lights stays on as well after stall I have to disconnect the battery otherwise it will drain it ivr changed the inner ingition switch still same prob any ideas guys im stuck please
No the car hasnt been touched with wiring it randomly started no Idea yeh the lights on straight away without ignition when you reconnect battery no turbo timer any ideas could it be a relay
I don't know the specifics with Sierra, but there may well be an ignition relay that is stuck in.
Connect the battery and start pulling relays out until the lights go off. Key out of course.
There are some under the glovebox. And more somewhere else lol
whats the inner ignition switch, sounds like the circuit in the ignition switch, , nothing to do with the ignition barell
remove lower cowling and when car is running ,
disconnect the plug with the thick wires,
this will shut down your car .. unless its a relay !
