fault code reader old skool
Old May 26, 2014 | 05:08 PM
martinmilne's Avatar
martinmilne
Default fault code reader old skool
Having clear out and tidy up in garage and came across an old fault code reader anyone have ideas to if there any good how to work them and ideas how much there worth
Old May 26, 2014 | 05:40 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
These are pretty good really as they give off flash codes which is now read up as fault codes (P,C,B,U) its good you still have the paper work as that will indicate where you need to connect(bridge) the machine
Old May 26, 2014 | 06:10 PM
Colin_P's Avatar
Colin_P
I used to have that exact same machine back in the day. Worked very well. I used it on my Granadas which had (I think) ECCIV ECU's.
When you use it, have a note pad to jot down the code, whcih comes out like morse code, and them look it up in the book.
Old May 26, 2014 | 06:41 PM
martinmilne
Are they worth much? Been in garage for years doubt I will use it now
Old May 26, 2014 | 06:44 PM
gingerturbo
Depends on people's work load they worth what anyone's prepared to pay, if you work on classics/pre 95/96 then its worth at least £20 a car
tankybaby66
Feb 6, 2016 02:24 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Digispurs
Ford Focus Range
Sep 16, 2015 09:47 PM
Si B
Sep 12, 2015 06:49 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
