Passionbmw peeps
Old May 26, 2014 | 12:25 PM
gingeRS's Avatar
gingeRS
Default Passionbmw peeps
Right, performed a turbocharger change on the 530d, everything came apart and went back together fine, the turbo whistle has gone but it doesn't seem to be making any boost?? There is a plastic accumulator between the actuator and the boost solenoid, and I think I might have connected it the wrong way round? What does this thing do?
Old May 26, 2014 | 02:12 PM
Churtz's Avatar
Churtz
Probably a 1 way valve.
Old May 26, 2014 | 04:50 PM
gingeRS's Avatar
gingeRS
Let's hope it's just that, what would it be needed for?
Old May 26, 2014 | 06:53 PM
Did you get it sorted then? ?
Old May 26, 2014 | 07:02 PM
Churtz's Avatar
Churtz
If you don't use them, it causes more strain on the solenoid as it would be under vacuum and boost at different stages. Rather than just boost.
Old May 26, 2014 | 09:03 PM
gingeRS's Avatar
gingeRS
Didn't have a chance to look at it, found this,
http://www.bmwland.co.uk/forums/viewtopic.php?p=913665
Think I've plumbed it wrong way round
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
cossie362
Oct 11, 2015 03:53 PM
paceo
Sep 25, 2015 08:05 PM
paceo
Sep 17, 2015 12:12 PM
