stuck in the slow lane
Old May 23, 2014 | 12:37 AM
TheGeordieStig's Avatar
TheGeordieStig
Default stuck in the slow lane
Hi guys having some problems with a 03 mondeo ghia x 130bhp 90ps tdci estate.
the turbo has stopped working so the car now performs like any non turbo heavy diesel car from the dark ages would.
doesn't hick or splutter when accelerating although mpg is quite down with having to use more throttle, there's no smoke problems out the exhaust, no noises, no warning lights fault codes or anything.
so have a couple of questions to ask
1/ what kind of turbo are they vacuum or electronic
2/ would an egr valve problem cause the turbo not to work (egr has been blanked off for a while)
3/ im checking through hoses for splits but could anything else stop the turbo from working
Old May 23, 2014 | 04:46 AM
dojj's Avatar
dojj
Resident Wrestling Legend
Is it variable vane?
If so the vanes may not be so variable now
Any lights on the dash or fault codes from the reader?
Old May 23, 2014 | 07:13 AM
gazza2502's Avatar
gazza2502
Old May 23, 2014 | 06:50 PM
TheGeordieStig
no fault codes present at all on the system and not lights on the dashboard. the car runs great apart from having no turbo
Old May 25, 2014 | 09:37 AM
stevo44's Avatar
stevo44
Hi the only way your going to find out the problem is to have a diagnostic done on it and you might find out its not what you thought it was ? i had one done at Fords for Ł40 three weeks ago.
Old May 25, 2014 | 06:41 PM
TheGeordieStig
yeah thanks stevo44 got my own snap on diagnostic no faults present, starting to think it may be the variable vanes unless theres a vacuum pipe off some where
Old Jun 3, 2014 | 12:31 PM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
You can't have both a 130 and a 90, they're two different models.
Old Jun 4, 2014 | 08:03 PM
TheGeordieStig
WHey hey problem fixed split in the back of the intercooler pipe.. back in the fast lane again thanks for your advice guys
Becka674
11
Oct 8, 2015 03:11 PM
gingeRS
17
Oct 2, 2015 09:42 AM
muz
Sep 30, 2015 08:29 AM
A.t.p
Sep 29, 2015 05:04 PM
