Remote servo advice
Old May 14, 2014 | 05:57 AM
QplateRST!'s Avatar
QplateRST!
1/4 mile beasty!!!!
Default Remote servo advice
I'm after some advice on running a remote servo setup with a tilton pedal box
Basically my servo and master cylinder on my mk2 base model fiesta are fouling my new gearbox setup I am wanting to run , and if I change to run an xr2 setup it fouls my jenvey inlet manifold so my only option is to run a pedal box setup from tilton , but after speaking to various people they say that the pedal you get from this is hard to use and that the brakes don't respond well, as my car is a road car with 425hp this isn't really and option!
So I've been looking into a remote serve setup and wondering can I just assist the front brakes and leave the rears straight from the pedal box? And also what type of sevro to go for?
Any help or thought welcome cheers Dean
Old May 14, 2014 | 11:35 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
can you not just shorten the brackets and shorten the rod on the servo?
that would be my port of call.
what box are you planning on running?
you could always move the servo up a touch, are you still on the base spec servo?
late spec brackets and a mondeo item may work better, i used them on my frs front brembo setup.
Old May 14, 2014 | 12:01 PM
studabear's Avatar
studabear
Has the Doc not had any ideas for this Deano?
Old May 14, 2014 | 02:21 PM
QplateRST!'s Avatar
QplateRST!
1/4 mile beasty!!!!
Mondeo servo it to big , xr2 servo hits my jenvey inlet base spec fouls the cable change on the gearbox Clarke had the same issue in his mk2 he ditched the servo and went for a pedal box option but said his brakes where rubbish
Il speak to the doc stu
mk3ste
Oct 17, 2021 10:09 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
rsguy
44
Sep 29, 2015 03:29 PM
Marv888
Sep 26, 2015 03:44 PM
