Svm850r r35 gtr v box results in finally got some race fuel out :)
well ive just got home from collecting my new car, I cant but help myself deliberating over the last 6 years or so and how my weekend/toy cars have progressed from the beginnings being a 470hp cosworth.
all I can say is if you've never been in one, my god as a driving experience they are genuinely mind blowing.
I have only run the lowest boost setting so far of 1 bar and honestly it feels as fast or faster than any other car ive driven, I will confirm with some vbox pulls in due coarse.
it is effortless to drive and the noise, oh my god the missus got a driveby vid but it hasn't come out its got that sound like the supercars have I am smitten with it lol
so the full spec
Titanium UK 2009 R35GTR – SVM950
Produces 862hp on Shell VPower, 978hp on 50% Ethanol
hubs 812 v power, hubs 928 v power/ethanol (e85) basically
Only 2600 miles since the new SVM/CNC Race engine was fitted.
Car has 24,000 Miles on clocks
Bodywork -
Oem bodywork
Rare titanium colour
Engine spec -
Svm/cnc heads race 3.8l engine fitted with:
SVM Forged Pistons,
SVM Race spec Conrods,
Cosworth*Headgaskets
ARP Head Studs
ARP Rod Bolts
ACL Bearings
Stock Camshafts timed to Race spec
Reworked Cylinder heads by CNC Heads
New Gaskets set
Fully assembled by Rick wood @ CNC Heads
Svm Billet Stage 6 gtx30 - 950bhp Turbos running 1.8bar of boost on ethanol
Full Gtc titan 4” exhaust system
Gtc Titan downpipes
Injector Dynamics 1300 injectors
2013 GTR Larger Turbo Intakes
Fuellabs pressure regulator
Garage whifbitz front mount intercooler kit
Garage whifbitz overflow tank
Walbro x2 450 lph*fuel*pumps
Fuel upgrade wiring kit
Svm 90mm intake system
K&N Filters
Ams 4 bar*map sensor
Ngk racing*spark plugs - NGK R2558A-9
x6 egt sensors linked to Syvecs -per cylinder
Drive-train & suspension -
Svm heat treated and superfinished gear set
Svm/GTC 16*Plate*Clutch*kit
Modified Baskets with Weld fix
Dodson gearbox circlips
Dodson drive locks
Dodson oil magnets
Titek diff brace
H&r lowering springs
15mm eibach spacer kit
H&R 10mm Wheel Spacers
Electronics -
Syvecs ecu with 8 maps and adjustable traction control
Syvecs flex fuel set up
Syvecs Bluetooth Module
Syvecs 4wd Control with Burnout mode
Toucan display linked to Syvecs for monitoring everything on the engine
Cobra cat 1 alarm
Tracker system
Oem cream interior
Bose*sound*system
Wheels and tyres -
20” oem wheels in great conditions
Toyos r888 (all round) 1000miles use
Hoosier Drag Tyres – Used 4 times
Notes -
24,000 miles (2,600 only on race engine)
Full service history
Fully mapped and calibrated by Syvecs - Ryan Griffiths
Power on v-power/ethanol mix Estimated 950bhp Flywheel (928@hubs)
Power on v-power Estimated 850bhp Flywheel (812@hubs)
and some pics needs a clean but honestly cant be arsed atm lol
you can waft along at 40 mph and it will sit in 6th gear at 1500 rpm burbling silky smooth ! slow moving in traffic crawling along no judders, rattles nothing just like a standard modern car would, my only gripe is with r888 tyres all round 315/35/20 rears, 285/35/20 fronts it whines so bad tyre noise it sounds like its got a wheel bearing gone lol, but they are needed to be able to use all the power, I can imagine its gonna be quite violent at 1-6 - 1.8 bar lol
and when you want some fun just tap the paddle shift once puts it in manual and then away you go but even in manual it will still shift 20 rpm before hitting the limiter so it is never touched, ryan has genuinely mapped the car to perfection.
I bought the car from ryan Griffiths himself it was his own personal development car that he used to make the syvecs kit fit the gtrs.
has cruise control, electric seats, displays to monitor everything as standard then extras all monitored by the syvecs ecu, its like a playstation car lol
I was questioning myself if im going mad spending this amount of money on a car but as a machine its in another league to anything ive ever had.
and best of all the missus and kids can get in and they all love it
my girls
the car will see some pod action once ive recovered from the shock of spending the amount ive spent
lmao
so the full spec
Bodywork -
Oem bodywork
Engine spec -
SVM Forged Pistons,
ARP Head Studs
ARP Rod Bolts
ACL Bearings
New Gaskets set
Gtc Titan downpipes
K&N Filters
Dodson drive locks
Dodson oil magnets
Titek diff brace
Electronics -
Cobra cat 1 alarm
Tracker system
Oem cream interior
Bose*sound*system
Wheels and tyres -
Notes -
my girls
lmao
I must say, I've never been that sold on these, not really my cup of tea, but I bet it's a bloody missile. Definitely one of the most impressive cars around.
im glad you all like it, I certainly do
it is amazing at 1 bar how quick it is but also how little drama there is it just gets up and goes, and with the shifts so quick and no letting of the throttle you never stop accelerating its just seemless power, I think this pump fuel dyno plot on a dyno dynamics tells it all.
now look at the size of that curve coupled with flat out instant gear shifts its constant pulling
Looks amazing and I imagine that can embarrass ALOT of bikes! Can only imagine the acceleration that thing pumps out, pinned to the seat behaviour I would think!! Just going to wait for that guy rod to come along and tell you it's not fast until you've done a vmax event or something to prove it
cheers neil its pretty mind blowing at 1 bar mate, at full chat like in that plot is 1.6 bar im sure its gonna be quite mad
Im looking forward to some real world data to compare against the fastest cars ive had previously.
Incredible car! My mate had one with 640hp and it did a pretty effortless 10.9 at Santa pod road tyres etc, so imagine yours would do a 9 at the pod. He did get beat by a shonky old Capri with a v8 in it tho, as seen on 5th gear.
lol it would take some cosworth to live with it steve
it blew me away mate it really did
I will take it once im used to it and know what all the controls are and ive recovered from the shock of spending so much
lol
I think even at 1 bar it will be a record breaker for me, im still very busy selling gtr parts and fixing tractors atm so not a lot of time but its here, its awesome and at the moment it needs nothing
lolI think even at 1 bar it will be a record breaker for me, im still very busy selling gtr parts and fixing tractors atm so not a lot of time but its here, its awesome and at the moment it needs nothing
my car has reportedly done a 9.8 1/4 mile on a vbox tarmac run I think on an airfield but that was no doubt on ethanol on nigh on 1000 hp.
I actually love the browness of it
I would say there will be alot of brown trouser moments in it, in the future. From yourself and from any passenger who has the balls to sit in an 850bhp GTR LOL
I do like the colour but il be honest if it was shit brown id of bought it for the performance alone
lmao lol the cream seats will stain easy too lmao
lol im with ya now mate
no doubt the stockers would get abit grumpy at 978 hp
I just found this on ebay, bearing in mind my motor has no head porting or cams so its stock dimensions just forged for strength, that's a lot of motor for Ł9k imo
http://www.ebay.co.uk/itm/3510679273...84.m1423.l2649
with some bigger turbos they make 750 hp, 650 lbft so ive read and are still reliable at that on a stock motor
Must be a hand full.
Did you pay 62k for it then?
I will stick with my poor mans performance car lol. Is there much room in the engine bay, will the engine be easy to work on.
lolit was advertised for Ł62k but we had a deal
cheers I think so, its a supercar without the pricetag imo
all in good time
its what sold it, well that and the fact the seller is a genuine guy and its my best ever shot at buying a highly modded one, its all a gamble but its minimised it enough for me to feel comfortable enough to buy it
