2wd and 4wd front bushes the same?
i have a full front 4x4 polybush set up and want to know will any of them fit the 2wd set up? also as a seller on here is advertising "4x4/2wd TCA's" its thrown me as i thought they were different!??
Pretty sure as they are the same.
The difference with the non cosworth tca are the bush size and bolt hole.Iirc the 2wd,4b and granada and escos are all the same.Three dr different because of the castle nut and not pinch bolt.
Let me check from when I got some new ones.It will be written down (I forget everything).
Oct 9, 2015 07:38 PM
FlashRS
13
Aug 31, 2015 06:02 PM
track.focus'd
Aug 12, 2015 05:53 PM
