Abs front and rear axle
As above .ive got a question
is about a 3 door cos,......ive had everything
Yellow Zinc Plated...
and i just wondered the front and rear hubs/axles are too,but the grey paint on the tooth for the ABS Sensors had vanished ,should i apply new grey for the abs sensors,or is it not important?....
thanks...
greetz Hans....
greetz Hans....
on the fronts the abs ring is part of the bearing pack
on the rears it's part of the cv/hub shaft
grease on either gives false readings to the sensors and causes problems, especially when the grease picks up a bit of crap and then it lodges in the sensor hole
Ok thanks all for the replys so far .
But i checked and there was grey paint,at least some sort of grey layer covering the teeth on the Hubs for the ABS sensor on my Car
My mate his 3 door ....has the same ""grey paint" on the Hubs covering the Teeth for the ABS sensors
http://s1053.photobucket.com/user/Ha...tml?sort=3&o=0
Oct 9, 2015 07:38 PM
track.focus'd
Aug 12, 2015 05:53 PM
