Diff oil
Mar 18, 2014 | 10:00 PM
Diff oil
What diff oil should I use in rear diff of my 3 door cosworth and how much do I need ?
Mar 19, 2014 | 10:03 AM
i'm using 75w/140 torco full synthetic,you need about 1-1.2lt
Mar 19, 2014 | 01:53 PM
I think I was recommended by Opie Oils the
TITAN Race SYN 5 75W-90 for a 2wd Sapph
Mar 23, 2014 | 10:21 AM
Silly question maybe , but how do you check the oil level?
Mar 23, 2014 | 10:39 AM
Quote:
Originally Posted by
paddy heffernan
Mobil SHC 75W90 Competition Gear Oil
Mar 23, 2014 | 12:46 PM
Harris.
Take the plug out and it should be 2mm from the hole
As above I used Silkolene Fuchs Syn5 fully synthetic. Mines 4wd and took 1.2 litres from dry
Mar 23, 2014 | 02:08 PM
Mine looks like it's be rounded off, star key so I'll get a new one.once I've got this one out
Mar 23, 2014 | 06:58 PM
Harris.
Should be an allen key mate not a torx
Mar 23, 2014 | 07:05 PM
saphcosmike
It's still rounded off mate
Mar 23, 2014 | 07:17 PM
Harris.
if it's bad, you could take the diff plate off and get it on the bench and weld a bolt on it if molegrips won't budge it?
Mar 23, 2014 | 08:09 PM
saphcosmike
I will try grips mate. I only wanted the check the oil as ive never done it and had the car 10 years
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
