limp mode
Old Mar 1, 2014 | 06:14 PM
adamjt7's Avatar
adamjt7
Default limp mode
Can anybody shed any light onto the problem I'm having the car is a 2.0 tdci 130 last week when driving I was going up a step hill and the car went into limp mode flashing glow plugs...I restarted the car and all was fine then did about 450 miles in it no problems then last Thursday it happened again and I cleared it and the car was fine since then it's doing it all the time I had the AA out who couldn't find a fault code with there reader I decided to look around the forums and first thing I did was clean the egr valve which was full of dirt.I tried the car and same is happening just so you know the car runs really smooth no lumpy tick over etc no white smoke just this limp mode problem soon as I press the throttle the car had new injectors fitted 12 months ago and a new fuel filter 8 months back and a reconditioned pump according to the paperwork could it be the cam shaft sensor...? As there is a lot on the forums about these failing.Just hoping anybody can suggest anything else before taking it to a garage....thanks
Old Mar 2, 2014 | 07:17 AM
oldford's Avatar
oldford
It could be a lot of things nowadays with all the electronics, but I suspect a boost problem.
Get it on a good specific Ford scanner and take it for a testdrive uphill.
With the glow light flashing you can retrieve the fault code(s).
Old Mar 2, 2014 | 10:42 AM
gazza2502's Avatar
gazza2502
Read my thread about turbo actuator , my bet is your turbos sticking
mark94
Oct 10, 2023 06:52 PM
fuzzy
Sep 4, 2015 10:11 PM
nick8saff
Aug 16, 2015 05:35 PM
